Author Topic: GameEx and Nester - how do you set it up?  (Read 1986 times)
redfivexw
  • Last login:March 11, 2025, 03:54:00 am
« on: November 18, 2006, 05:27:14 pm »
Hi,
i am currently running Gameex and love it, however i am now trying to add different emulators.  I am starting with Nester and Nes roms.  the setup screen for gameex asks to browse for the .INI file for the emulator, but i dont know how to get that.  I dont currently have that file, just the nester program and the roms which work with windows.  what do i need to do?
headkaze
  • 0x2b|~0x2b?
Re: GameEx and Nester - how do you set it up?
« Reply #1 on: November 19, 2006, 03:18:24 am »
You can check out the new user guide
Or visit the support forums (highly recommended, if you want an answer directly to your problem).
There is no config for Nester currently with GameEx, so you might need to ask or check out the User Submitted Configs forum.
Just ask on the forums if you have any problems. I will get a Nester config added to GameEx if it's possible to have it running in full screen. I know there are configs for NEStopia and VirtuaNES if you want to try those instead.
redfivexw
« Reply #2 on: November 19, 2006, 05:04:41 pm »
thanks, i will give the other emulators a try then.
redfivexw
« Reply #3 on: November 20, 2006, 07:02:18 am »
I still dont get it, i still dont find a .ini file.    :hissy:
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: November 21, 2006, 09:50:22 am »
They should be located in C:\Program Files\GameEx\CONFIG\EMULATORS\IMPORT-EXPORT
