Author Topic: Supergun problem  (Read 1375 times)
hammad
  • Last login:August 14, 2011, 04:23:27 am
Supergun problem
« on: November 18, 2006, 01:16:18 pm »
Hello,
My supergun's 1 player controller sometimes stops working and then starts working again....none of the buttons work on it but 2 player control always works the problem is only with 1 player controllers sometimes it works perfect and sometimes it completely stops working....why could this be happening ....
BobA
  • What Me Worry?
Re: Supergun problem
« Reply #1 on: November 18, 2006, 07:35:47 pm »
Sounds like a bad connection or loose ground on the Player 1 unit.   Check the connector that plugs the controller into the supergun and trace the ground wire thru the controller.  A ground problem could be on the supergun side or the controller side.
hammad
« Reply #2 on: November 20, 2006, 12:13:42 am »
Thanks BobA , I checked the connections of ground and then again soldered them but the problem is still there ....
BobA
  • What Me Worry?
« Reply #3 on: November 22, 2006, 04:47:49 pm »
Did you also check the daisy chained ground wire that goes to all the button and joystick grounds?
If you have you could als check the Jamma connector ground that the P1 gnd connects to.
