Author Topic: Control Panel Feet  (Read 1377 times)
Searcher7
  • Last login:June 21, 2009, 10:45:22 pm
Control Panel Feet
« on: November 16, 2006, 11:16:04 pm »
Do any of you guys use "feet" under your stand alone control panels?
My Super Gun's have these little circular rubber "donuts" that screws go through to secure them to the underside of the CP.
I just don't know the name of them.
Anyone?
Thanks.
Darren
RandyT
  • Last login:June 24, 2026, 02:15:54 pm
    • GroovyGameGear.com
Re: Control Panel Feet
« Reply #1 on: November 17, 2006, 12:40:38 am »
They can be called recessed bumpers, or just "rubber feet."
Most industrial supply houses have a selection to choose from, ranging from the type you described, to solid with bolts protruding from the backs, as well as self-adhesive varieties.
RandyT
NIVO
« Reply #2 on: November 17, 2006, 01:55:26 am »
if you have a lowes in your area, check right next to the cabinet door hinge section. Adjacent to that in the same aisle should be door locks and cams. I've been in 3 lowes in my area and all are located in this section. Good luck to ya.
