Author Topic: Multiple consoles on arcade monitor - remedial help needed!  (Read 2663 times)
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« on: November 16, 2006, 01:44:41 am »
I'm usually pretty good technically, but am at a loss on this one.
How do you hook up the video for multiple consoles to an arcade monitor in a mame cabinet.  Let's use the following situation:
- Arcade monitor (Betson, WG, Billabs, etc.)
- Mame PC w/AVGA card already connected to arcade monitor
- Slikstik CP (w/ipac)
- Xbox and PS/2
- Ultimarc console adapters for Xbox and PS/2
How is the video for the Ultimarc adapters connected to the monitor?  Do you need a jpac(s)?  Do you have to manually move the monitor video cable when you switch sources (mame PC to Xbox to PS/2)?  Or can you connect all three sources to the monitor and switch them via software or keystrokes?
I did some hunting on this an could not find a clear (at least to me) answer.  I think I understand how the console swould both connect to the ipac for controller use.  It's the video I don't get.
AlanS17
    • AlanS17
Re: Multiple consoles on arcade monitor - remedial help needed!
« Reply #1 on: November 21, 2006, 10:42:09 am »
I'm assuming by "arcade monitor" you mean a CGA monitor. What sort of video cables do you intend to use for the XBOX and PS2? Are you going to use S-video, component, or composite signals?
There's no reason why you can't hook up all your sources directly to video. Using a J-Pac limits your compatibility with the XBOX and PS2. You can probably use an off-the-shelf A/V switch, but you'll have to do something about that AVGA input signal. And you'll need a way to split the sync signal off when you send the final video signal to arcade monitor.
The beauty of the A/V switch is that it will also switch over your audio source. That's something you may not have considered.
As far as controls go, maybe you can find some PS/2 splitters and run your controls to all 3 consoles at once. Then at least will be a seamless transition. Otherwise you'll have to sheel out some money for a switch for that, too.
I REALLY don't want to have to draw a diagram, but I will if this all doesn't make sense.
*Note: that PS/2 refers to the PC keyboard standard and PS2 refers to the Playstation 2.*
scumball
  • Last login:September 24, 2019, 02:23:47 am
« Reply #2 on: November 21, 2006, 03:38:33 pm »
I use a JPAC and have just ordered a Belkin KVM with audio switcher.  If you're using the Ultimarc console AV adaptors you could use this too and it comes in a 4 port version.
Input of KVM from XBox video/audio/control adaptors
Input of KVM from PS2 video/audio/control adaptors
Input of KVM from Pc video/audio/keyboard
Output of KVM Keyboard to IPAC
Output of KVM Video to Video Amp to Arcade monitor
Output of KVM audio to Amp/Speakers
albert_c
  • Last login:April 06, 2010, 03:57:07 pm
« Reply #3 on: November 22, 2006, 01:47:32 am »
Don't even try this.  Use a T.V instead or use multiple cabinets.
johnvv
« Reply #4 on: November 22, 2006, 03:35:35 am »
The noted monitors all have VGA inputs.  In this scenario, the Billabs has an advantage in flexibility as it can display up to 1024 x 768 versus 800 x 600 for all the other arcade/CGA monitors.
So, with only a VGA input on the monitor, all the consoles would have to hook up to VGA - either directly or via a transcoder or switchbox.
I was hoping that there was one box that could switch the VGA from the PC, component from Gamecube, Wii, and PS2, and VGA from the Xbox/Xbox 360.  Doesn't sound there is - at least under $500.  Yeah, multiple cabinets would work, but buying a high-end mult-format video transcoder would be far less expensive.
Sounds like a VGA switch in combination with a couple transcoders (one for each of VGA and component) would work but will still require some manual cable switch and/or button pushing.  An A/V switch is another good idea for audio even if can't handle the VGA requirements (due to lack of ports or switching capability).
AlanS17
    • AlanS17
« Reply #5 on: November 22, 2006, 08:16:06 am »
I would check online for a KVM switch with additional audio switching.
albert_c
« Reply #6 on: November 22, 2006, 07:15:40 pm »
The worst part about this type of deal is that you have to re-adjust the  video settings everytime you change to a different system.
AlanS17
    • AlanS17
« Reply #7 on: November 23, 2006, 01:29:22 pm »
High-end KVM switches will help adjust the signal. It shouldn't cause an issue for a multi-sync monitor, anyways.
