Author Topic: 4-way leaf joystick  (Read 1549 times)
Keith O
  • Last login:March 15, 2006, 04:55:42 pm
  • Get off me cheese!
4-way leaf joystick
« on: March 27, 2003, 12:50:44 am »
I'm familiar with Oscar's restrictor plates but I'm looking for a hidden 4-way restrictor plate for a Wico 8-way leaf joystick that I already own. Is there such a beast?
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
Re:4-way leaf joystick
« Reply #1 on: March 27, 2003, 01:29:58 am »
Pre-fab, I am not aware of. You could try something like in this post though. Could be a neat project:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=5983
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #2 on: March 27, 2003, 01:45:59 am »
Are you looking for a permanent fix?
If so, instead of drilling a round hole on the CP for the joystick to go through, cut a diamond. You would need to go small enough so that if you push the stick all the way left that it just touches the point of the diamond, same with up/down/right
I don't know how long it would take for normal use to 'erode' your cutout- obviously a metal CP would last almost forever, mdf would be about the softest.
Using a wood/plexi or lexan layered CP, you could cut the wood hole to normal 1-1/8" size and cut the smaller diamond just through the plexi/lexan
Visible wear would be covered by the plastic disk, also
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #3 on: March 28, 2003, 10:50:24 am »
The problem with cutting a diamond-shaped hole in your control panel is that if the dimensions are off by a tiny bit (someone said as little as 1/16) then the restrictor will cease to function, or won't allow the top/sides to be pressed.  If you try cutting the hole in your panel and mess up, your whole panel is scrap.  It's much better to use an add-on plate.
-Ace-
I want my own arcade controls!
