Author Topic: Fixing old arcade cabinet to Mame cabinet  (Read 1732 times)
MarkH.
« on: November 14, 2006, 09:39:53 pm »
I purchased an old arcade cabinet that has all the controllers already still in the system.  there is no screen.  the controls are all wired into 1 connector (as you can see in the pics on my site), I was wondering if there is a connector that this can go into, which can then go into a usb for a computer?   If possible i would prefer not to replace all the controls.  any help would be much appreciated!
http://www.geocities.com/dude-ly/arcade
mark
dude-ly@rocketmail.com
sidekick
Re: Fixing old arcade cabinet to Mame cabinet
« Reply #1 on: November 14, 2006, 11:24:03 pm »
you can pick up an encoder and rewire the controls...
you may want to search around when it comes to deciding on a keyboard encoder
the two most common places for keyboard encoders are:
http://www.ultimarc.com
http://groovygamegear.com
what games do you plan to play for your system? You do realize that that CP is limited to 3 buttons per player, so if you plan on playing fighter games you may want to pick up 3 more buttons per player.
MarkH.
« Reply #2 on: November 16, 2006, 04:01:18 am »
do i have to rewire the controllers?  i just got a message from somebody else saying to just buy one of these http://www.ultimarc.com/jpac.html and thats all i need.    he didnt say too much else.  i just want to have everything set out in my mind in how i want it before i go buying anything.
thanks for the tip on the buttons.  i never thought of that.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #3 on: November 18, 2006, 06:01:57 am »
In case that guy didn't PM you again:
Yes. the jpac is all you should need, and you won't need to rewire them; just plug it into your jamma connector.  If you decide to add more buttons they can be wired to the screw terminals.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: November 19, 2006, 05:45:08 pm »
Agreeing with NickG (assuming that is a JAMMA harness as it appears to be), except you will still have a monitor issue.
Now, if you plan to use a PC monitor, then you can ignore the video-on on the JPac and things will be fine.
If you want to use an arcade monitor, then you will need to connect your monitor to the JAMMA harness a video card that can drive the arcade monitor (standard arcade monitor runs at 15Khz, standard PC monitor at 31Khz) and will plug your VGA cable into the video-in on the JPac.
More info can be found in the wiki and the Monitor forum.
NOTE: The JPac has spots to connect buttons 4-6 (which aren't part of the JAMMA specification, so not on the harness), so don't worry about that.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
markh.
« Reply #5 on: November 20, 2006, 10:19:22 am »
Cheers.
thanks guys for your input.
one last question, how big of a differnce would the video be for an arcade monitor vs a tv?  are arcade monitors easy to come by?
shardian
« Reply #6 on: November 20, 2006, 02:31:52 pm »
http://www.oscarcontrols.com/monitors.shtml
This article was very helpful when I first got into this stuff.
