Author Topic: Router form thickness  (Read 4353 times)
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« on: November 06, 2006, 12:05:39 pm »
I'm going to try my hand at routing a hole for my coin door and I've made up a template out of a thin sheet of old masonite.  It's maybe 1/8" think.
My question is, will this be strong enough to guide the router when I go to cut the hole in the actual front board piece? (It's about 5/8" laminated particle board)
  • Last login:June 29, 2026, 03:23:15 pm
Re: Router form thickness
« Reply #1 on: November 07, 2006, 09:10:19 pm »
As long as the ball bearing depth is set properly to run along the template I don't think it will be a problem although a 1/8" thick template is kind of thin...
_) (V) (-)
« Reply #2 on: November 08, 2006, 11:21:53 am »
That's what I was thinking. Maybe I'll parctice on a hunk of plywood first. If it works I can use the plywood as the new form.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #3 on: November 18, 2006, 01:05:48 pm »
I use 1/2" baltic birch plywood for all of my templates. 3/8" would probably do fine as well. 1/8" is too thin.
It's 9am. I'm calling it a nite.
miles2912
« Reply #4 on: November 20, 2006, 08:12:59 pm »
Jig saw would be much easier.  Trace the pattern on a piece of cardboard and cut it out to make sure it will work.  Then trace the pattern on your wood and use a jigsaw to cut it out.  I wouldn't use a router here.
D-
NiteWalker
« Reply #5 on: November 20, 2006, 09:12:42 pm »
I use the jigsaw to get the templates close to where I want them. Then I sand them perfect and use the template with the router. Flawless technique.
