Author Topic: Cannot get Gauntlet working in MAME .106 after hours and hours  (Read 6520 times)
MartyNg
  • Last login:April 26, 2014, 11:37:48 am
« on: November 03, 2006, 07:25:08 pm »
I've downloaded many different versions of Gauntlet, and have tried rebuilding the roms with clrMamePro until I was blue in the face.  I simply need to get this one game working in MAME 106. Is there an easy way to do this? Whenever I start it up, I am always missing files. Even following CLRMame tutorials I am still not understanding what to do with CLRMamepro. Thank you for helping.
« Last Edit: November 04, 2006, 10:52:34 am by MartyNg »
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Re: Cannot get Gauntlet working in MAME .106 after hours and hours
« Reply #1 on: November 05, 2006, 12:36:11 pm »
Which gauntlet are you trying to get working?  The original ones or the newer ones?  Which files are you missing?
FunWithFire
  • Last login:July 07, 2009, 01:17:30 am
« Reply #2 on: November 06, 2006, 05:27:00 pm »
Don't you need the CHDs for Guantlet Legends and Dark Legacy?
MartyNg
« Reply #3 on: November 06, 2006, 06:11:47 pm »
Primarily I want the original Gauntlet to work.
The following files are missing from my current build of the rom.
74s472-136037-101.7u
74s472-136037-102.5L
74s472-136037-103.4l
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #4 on: November 06, 2006, 07:19:52 pm »
Yes those are needed for the original gauntlet. You do not need any CHD's.
MAWS is a quick on-line way of seeing what roms are required for mame to run what game:
http://www.mameworld.net/maws/set/gauntlet
Seeing as you have used ClrMame (which will correct any old spellings etc..etc...) it looks like your 'source' for the gauntlet roms is incorrect/incomplete.
I believe that those 3 files are the "proms" which were only added to mame since version 0.105u4. This is probably why what you have does not work as they are slightly out of date. So its possible that a version of mame before 105 (e.g 0.104) may well work with what you have (although roms may have changed name).
You can get Mame 0.104 here:
http://www.mame.net/zips/mame0104b.zip
Note, if that fails, don't ask about downloading roms as its against the rules.
