Author Topic: 800x600 or 640x480 for TV  (Read 2899 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: November 01, 2006, 07:00:13 pm »
I am going to be using component out on my mame cab.  Will my 27inch TV display 800x600 or will it only do 640x480.    Will 800x600 be good looking on a tv ?
unclet
Re: 800x600 or 640x480 for TV
« Reply #1 on: November 01, 2006, 07:37:57 pm »
I would think it depends on the type of TV as well as how nice of a TV card you will be using...
TalkingOctopus
    • My Arcade
« Reply #2 on: November 01, 2006, 10:57:46 pm »
I prefer 640x480 w/ S-Video on my TV, (component is not an option for me).  I think you're going to have to try both resolutions and decide for yourself here.  It shouldn't be a difficult test.
« Last Edit: November 01, 2006, 11:10:42 pm by TalkingOctopus »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: November 01, 2006, 11:15:28 pm »
You will have overscan.  If you keep searching, you'll find ways people have combated that.  I love the component look as compared to s video, so it's well worth the hassle.
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« Reply #4 on: November 01, 2006, 11:35:13 pm »
I've only had the scrolling desktop with 800x600 with component video and I run 640x432, everything fits perfectly. I use powerstrip's arcade setting and that's about it.
GT
TalkingOctopus
    • My Arcade
« Reply #5 on: November 01, 2006, 11:45:48 pm »
What videocards are you using w/ component out?
rdowdy95
  • This is my rifle.
« Reply #6 on: November 02, 2006, 01:21:55 pm »
This is the video card I have:
http://www.newegg.com/Product/Product.asp?Item=N82E16814125022
It is a Radeon X1300PRO.
I am going to build the computer in a couple of weeks.  I am cutting my T-Molding slot and doing the rest of the sanding this weekend then I need to stain it during the week.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #7 on: November 02, 2006, 07:17:25 pm »
I use 640x480 on my 27" JVC.  The TV's service menu along with Powerstrip helps to constrict the screen just enough to fit it perfectly.
I'm not sure I would've been able to get 800x600 on there.  The only purpose to do such a thing would be if you plan on using Windows at various times, or for premade layouts for frontends.  Otherwise, is there any reason to use 800x600?
I have an ATI as well.  Something in the low 9000s I believe.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #8 on: November 02, 2006, 10:11:48 pm »
Note that if you are just using Tv-out (S-video probably) then by changing to 800x600 you are not actually outputting a signal that is 800x600. In fact its probably very similar to 640x480.
The gfx cards all have on-board chips that generate a TV-compatible signal from your output. So 800x600 will generate a similar size screen, but everything will be smaller and text harder to read etc.... The difference in mame games will probably be quite small, windows desktop/frontend more noticeable.
MrQuan
  • Last login:October 30, 2008, 03:47:14 am
  • Well, at least you threw a punch...
    • Tilt Arcade - Check it out!
« Reply #9 on: November 07, 2006, 10:25:43 pm »
I have a 68cm TV, and I'm using component at 720x576@60 (This is a specified HDTV resolution I think).  My video card is a NVidia 7600GS and I chose one of the component presets in the driver settings.  800x600 was a little too high for me as I had to up the fonts in my FE etc to be clearly ledgeable anyways.
Everything works perfectly, no overscan, and graphics are SHARP compared to my old S-video 640x480 setup ;D
