Author Topic: CPU Problem  (Read 1829 times)
bsgamble
  • Last login:October 27, 2006, 07:46:58 pm
CPU Problem
« on: October 27, 2006, 06:08:03 pm »
I just put in a new fan on my CPU because the old wasnt sufficient enough.  Well i dont know what it is that Ive done but when i turn the PC power on now the fan comes on as it should but NOTHING else is getting power (keyboard, mouse, etc.) What could it be?
sealslayer
  • Last login:March 18, 2014, 04:41:30 pm
  • Why screw when you can bolt
Re: CPU Problem
« Reply #1 on: October 27, 2006, 06:11:41 pm »
MOBO or CPU has gone pop, Did you tamper with the heatsink at all? :dunno
bsgamble
Re: CPU Problem
« Reply #2 on: October 27, 2006, 06:15:08 pm »
yeah its a new fan plus heatsink
sealslayer
Re: CPU Problem
« Reply #3 on: October 27, 2006, 06:26:58 pm »
May seem like a silly question but did you put the heatsink on the correct way and use thermal paste?
I've made the mistake in the past of putting the heatsink on incorrectly, it looked correct but burnt the CPU out in a matter of seconds.
Does the numlock light on the keyboard light up?
bsgamble
Re: CPU Problem
« Reply #4 on: October 27, 2006, 07:47:31 pm »
Nothing at all is lighting up.  You know that may be exactly what i did too.
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
Re: CPU Problem
« Reply #5 on: October 27, 2006, 10:02:57 pm »
Well,
It is likely that your CPU go burnt, but when installing the heatsink did you do anything that may have grounded the Mobo?
Also, unplug the CPU fan and start the computer (if you get to the BIOS shut off the computer so you don't overheat).   If there is a short on the Fan it will caouse this.
Nothing witty here...move along.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
Re: CPU Problem
« Reply #6 on: October 28, 2006, 08:52:44 am »
I've had a few older boards that would not boot is the fan was connected to the system fan header instead of the CPU fan header.  Maybe check that.
