Author Topic: Microatx and atx  (Read 1380 times)
SithMaster
Microatx and atx
« on: October 26, 2006, 03:22:23 pm »
my pc case sports a microatx case but could i use an atx mobo as a replacment?
there is room for a bigger board to fit so aside from potential air flow problems would it work.
Re: Microatx and atx
« Reply #1 on: October 26, 2006, 03:27:34 pm »
Your PC case has another case inside it?
It is for smuggling?
boykster
  • The cake is a lie!
« Reply #2 on: October 26, 2006, 03:33:19 pm »
most atx cases will fit either a mAtx mobo or an atx one.
If it is an mATX case, it probably won't fit a standard ATX motherboard.
If an atx board will fit, it should work fine.....
« Reply #3 on: October 26, 2006, 03:47:21 pm »
Either way, if you have a motherboard and a case, and you have a drill and some screws, you can make it work.
SithMaster
« Reply #4 on: October 26, 2006, 03:57:44 pm »
i figured i could drill holes but id rather not.
ill try hecking if i have a atx and see if it works.
the thing is the case has a micro in it but it seems to be a medium case for a atx.  i checked dimensions on tomshardware and it seems like mine is capable of holding a atx.
danny_galaga
  • Last login:June 17, 2026, 12:38:52 am
    • dans cocktail lounge
« Reply #5 on: October 28, 2006, 03:52:22 am »
if you screw it up youll be hecking all right!
