Author Topic: Jukebox hunting again...  (Read 4066 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: October 21, 2006, 04:04:45 pm »
I've found three so far in my price range. Two are AMI (Not Rowe/AMI), and one is a Seeburg. All are from the 1950's. All are cheap as crap.
  • An AMI F-120. Untested, needs paint, but complete. $200, 80 miles away. Nice machine, but almost a quarter of a ton in weight.
  • An AMI I-200. Fully working, needs cosmetic restoration and amp capacitors. $300, 30 miles away, and less weight. Main problem is current owner has no idea on how to get it out of his basement.
  • A Seeburg Q160. Needs electronic/mechanical restoration. $150, 45 miles away. Has the complicated Tormat selection system.
I'm split between all three. Opinions? Here are some pics. Top is the F-120, middle is the I, but a 120 selection model, and third is the Q160.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re: Jukebox hunting again...
« Reply #1 on: October 22, 2006, 03:41:40 pm »
The best place to ask would be over on the alt.collecting.juke-boxes newsgroup (use google groups if you aren't setup on newsgroups with your ISP).
While not a very active group, it is regularly monitored by those heavily into collecting and restoring old jukes.  I'm sure somebody there could give you some ideas about sound quality, reliability, repairability and parts availability for each of those jukes.
Regards,
D
Barry Barcrest
  • Last login:December 15, 2025, 05:01:48 pm
  • Simple Plan
    • E-Touch Jukebox
« Reply #2 on: October 24, 2006, 05:22:31 am »
Why not just buy them all, i'm sure your parents can afford it  ;D
fredster
  • It's all good!
« Reply #3 on: October 25, 2006, 03:44:51 pm »
That was mean Barcrest.
USSEnterprise I guess you don't have any help.  Somebody put that in the basement and some people can get it out. You need a heavy duty dolly and 3 guys.  You can get it out then.
Check www.gameroommagazine.com to see if there is an arcade auction in your area.  They have working ones there you can load up for about $200.
Or buy this - one -
Goz
  • KOTA
« Reply #4 on: October 25, 2006, 04:14:10 pm »
I have a seeburg from a year or two earlier. It is very heavy. Might look for a fourth guy to help lift.
KSKID
  • Last login:January 02, 2025, 01:37:21 pm
« Reply #5 on: October 26, 2006, 11:17:05 am »
i like the looks of the seeburg 160, that would be my pick
Ken Layton
  • Guru
  • Technician
« Reply #6 on: October 26, 2006, 11:38:32 am »
That Seeburg Q has a very difficult to recap amplifier---extremely complicated. I would avoid it.
The AMI I is a very pretty machine and has a fairly straight forward sound system which is easy to work on. This is the juke I would choose if I were you.
USSEnterprise
    • USS Odyssey
« Reply #7 on: October 26, 2006, 05:06:53 pm »
Updates...
The AMI I turned out to be an AMI F with a cracked glass, which really doesn't matter, since the F will not fit in our SUV. The Seeburg has major water damage to the painted glass, so I am going to stay away.
BTW, like all my other pinball machines, soda machines, etc, I am paying for this myself. :lame:
