Author Topic: Ques about Happ Super adjustments  (Read 1113 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: October 21, 2006, 01:00:20 pm »
Hello all,
I have my happ Super top mounted and recessed just enough to hide the mounting plates. The Super comes with 2 sleeves for the shaft. Longer for wood panels and short for metal panels. At first I used the shorter (thinking since this is top mounted) but the spring seemed too tight. Now I have installed the longer at the spring feels better but the handle has an awful long throw to it. Is there way to use the shorter and have the spring a little more loose?
My old user name was marlborroman13, but I kicked the habit many years ago!
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
Re: Ques about Happ Super adjustments
« Reply #1 on: October 22, 2006, 11:22:56 pm »
You could try replacing the spring with a lighter one.
I don't know if this is even a possibility...seems it would be.
You could also try a Happs Comp. Much lighter springs in those. I think they have the same footprint.
Xam
Can't talk to a psycho like a normal human being.
