Author Topic: How do i setup the Hard drive for a MAME cabinet  (Read 1383 times)
1942junky
  • Last login:October 15, 2006, 09:23:37 am
« on: October 09, 2006, 08:43:39 am »
I am just about to start my first cocktail project, after alot of research, the only thing i'm not sure of is how to set the hard drive up. As far as i can tell i should be using MAME & ArcadeOS, i want to run DOS only instead of windows, i am assuming this keeps the system simpler and quicker to start up.
Any advise would be appriciated.
Thanks.
daywane
  • GRRRR!
Re: How do i setup the Hard drive for a MAME cabinet
« Reply #1 on: October 10, 2006, 07:38:07 pm »
set it up as you would any hard drive
mame is program just like any other program
as far as the dos VS windows ... Thats all up to what you are used to going with.
Me... Never played with dos. so windows was best for me.
loadman
  • Last login:Today at 05:15:31 am
  • MaLa FE developer
    • MaLa
« Reply #2 on: October 10, 2006, 08:26:39 pm »
If your PC is slow use DOS and Gamelauncher
If you have a half decent PC you would be crazy not to use Windows XP and one of the latest FE's  (MaLa, Atomic. MameWah etc)
Check the Wiki
http://wiki.arcadecontrols.com/wiki/Front-Ends
« Last Edit: October 10, 2006, 08:42:55 pm by loadman »
