Author Topic: OK, I'm starting to think this does not exist...  (Read 2507 times)
Justin
  • Last login:March 13, 2026, 07:40:07 am
    • Centipede MAME cabinet
« on: March 23, 2003, 02:40:56 pm »
I'm giving up on this!   >:(
I need a TV for my cab with the following specs:
-Anywhere from 22" to 25" diagonal viewable
-Max. dimensions W: 23.75"   D: 20"
-Must have S-Video input
I've looked and looked, all 25" lack S-Video.  And the only one I found with S-Video is too big  :'(
This one:
25" TV at K-Mart
Someone help me before I go crazy :P
« Last Edit: March 23, 2003, 02:41:58 pm by Justin »
"3 warps to Uranus" -- so I stopped playing!
BobA
  • What Me Worry?
Re:OK, I'm starting to think this does not exist...
« Reply #1 on: March 23, 2003, 03:08:33 pm »
Here is one that is a bit small but fits your dimensions.  Did you consider mounting without the case to reduce the size a bit?
http://www.bestbuy.com/detail.asp?e=11102176&m=1&cat=24&scat=28
BobA
Justin
« Reply #2 on: March 23, 2003, 03:37:42 pm »
I forgot to mention I did not want a flat screen  :)  It will kill the experience, as all classic cabs used curved monitors.
Oh, I'm getting too picky... argh! :/
Oh, removing the enclosure from the TV is out of the question, as I'm scared to death of high voltages in tubes.  This is why I went with a TV instead of a Wells Gardner in the first place.
-J
« Reply #3 on: March 23, 2003, 04:49:06 pm »
Use the WG, just don't plug it it until you've finished the cab!!
