Author Topic: Windows XP "Last Known Good configuration" 2 Sec annoying screen  (Read 1512 times)
mrclean
    • Guscade
Windows XP "Last Known Good configuration" 2 Sec annoying screen will load up right after my splash screen? its annoying as i already had mentioned is there any way to get rid of it.. basically it will sit and count down for about literally 2 seconds and automatically launch it to the last known good configuration, which is fine.. i just dont want to see that message because ive worked really hard to hide majority of the windows environment up til now!
2,370,650 Gun.Smoke
cdbrown
  • Bowowow
Re: Windows XP "Last Known Good configuration" 2 Sec annoying screen
« Reply #1 on: October 08, 2006, 04:52:07 am »
There's something wrong there as that should only pop up if you are properly shutting the pc down - ie crash - or there is something wrong with the registry.  Better check that all the drivers are installed properly or you haven't removed something from xp during the 'hiding' process.
Found this here
 The "Last Known Good" configuration is one of the available startup options in Windows NT 4.0, Windows 2000, Windows XP and Windows Server 2003. It starts the computer by using the registry information and drivers that Windows saved at the last shutdown. Any changes made since the last successful startup will be lost.
The Last Known Good Configuration startup option allows you to recover from a problem by reversing driver and registry changes made since you last started Windows XP/2000/2003. Windows does not update Last Known Good Configuration information in the registry until the operating system successfully restarts in normal mode and a user logs on and is authenticated.
