Author Topic: Where can I buy good cheap clamps?  (Read 5808 times)
« on: October 03, 2006, 10:33:54 pm »
Preferrably 24" or more.  Does anyone know where I can order some?  Thanks!!
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
Re: Where can I buy good cheap clamps?
« Reply #1 on: October 04, 2006, 10:15:46 am »
Harbor Freight if you have one nearby.  They have decent sales.  Not the best quality though.
Next I'll be on fries, and that's when the big money starts rolling in.
« Reply #2 on: October 04, 2006, 10:26:16 am »
For 24" or more I'd probably use pipe clamps.  Cheap, variable to any length.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #3 on: October 05, 2006, 02:08:40 pm »
Pipe clamps are cumbersome and overkill for a 24" throat. I would use the F-style clamps from Harbor Freight or the aluminum bar clamps from Harbor freight. Either can be had quite cheap when on sale and both are reasonably decent for the dollars spent. I have 2 dozen pairs of each style in different length. I just buy 2 at a time if I'm in HF and they are on sale.
If you decide to go full woodworker spend some dollars on clamps. Get a Bessey cabinet maker set or something comparable.
F-type clamp:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=5976
Bar clamp:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38183
Avoid buying the "Quick-Grip" style clamps from HF. They are not good at all.
Nannuu
« Reply #4 on: October 05, 2006, 02:24:44 pm »
I have quite a few sets of "good" clamps and the a bunch of HF clamps for clamping in between.  I've found that the HF's tend to slip some, or bend or something.  For the price, they work for most of the junk I do.
Gambit
  • Last login:November 16, 2006, 09:40:19 am
    • The BlueSparks Network
« Reply #5 on: October 06, 2006, 12:12:42 am »
I must have 30 clamps of various types and sizes.
Its funny that I have that many when I only do woodworking as a hobby.
prOk
  • Last login:December 28, 2015, 08:29:34 pm
  • www.rgvac.com
    • Brian's Classic Arcade
« Reply #6 on: October 08, 2006, 01:05:32 am »
A good clamp is worth the money.. you want a hardened steel clamp.. you can get the 'f' style at just about any home center that is hardened for about 15 bucks each in 24 inch length.     Stay away from the crapola at harbor freight as you will experience slippage, the clamps will bow and as a result throw your project out of square as it mars the side of whatever you're clamping.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #7 on: October 14, 2006, 07:50:26 pm »
HF does have some decent clamps...and some bad ones. The ones made by Pittsburgh at HF are nice for the price. If you want to spend some money on them Jorgensen or Irwin are nice.
Xam
Can't talk to a psycho like a normal human being.
« Reply #8 on: October 16, 2006, 10:50:47 am »
Probably true.  I tend to use them because I already have pipes for them in various lengths because old pins often need rework in the cabinet itself.
