Author Topic: GameEx 6.90 Released. With a new Setup Wizard!  (Read 1444 times)
headkaze
  • Last login:July 05, 2026, 01:56:04 pm
  • 0x2b|~0x2b?
« on: October 01, 2006, 06:14:06 pm »
Introducing the GameEx Setup Wizard!
A new innovation in gaming frontends - The GameEx setup wizard allows wizard style configuration, download, setup of GameEx, MAME, emulators and all your media needs.
This makes the setup of GameEx even easier than it ever it was.
Now the gaming frontend with the most complex backend and amount of features, is probably now the easiest to setup and use.
The GameEx setup wizard is entirely the work of Ben Baker (AKA Headkaze).
You should get this version of GameEx as soon as you can.
Please give feedback and ask questions about this new addition to GameEx on the GameEx forums.
My thanks, gratitude and admiration go out to Ben.
The Setup Wizard should help out new users alot. If GameEx wasn't easy enough for you to setup before, this should help you out. If your a new user considering a FE, then now is the time to check out GameEx.
Please report any bugs or problems to the GameEx forums.
