Author Topic: Vertical Hold problem - monitor does not have vertical hold adjustment?  (Read 3028 times)
arzoo
  • Last login:Yesterday at 10:56:07 am
  • Robots WILL kill you.
    • LEDBlinky
Hi,
I'm using a Dotronix video monitor (purchased from GGG) and I just recently installed an ArcadeVGA card in my pc. From the windows desktop at 640x480 everything is fine. But when I change to higher resolutions (800x600) the vertical hold does not work (screen starts scrolling). The monitor has auto vertical hold and there's no adjustment. Is there some way to solve this problem?
Robots will kill you.
Arcade Addiction
arzoo
    • LEDBlinky
Re: Vertical Hold problem - monitor does not have vertical hold adjustment?
« Reply #1 on: October 01, 2006, 02:24:13 pm »
Randy at GGG has confirmed that the monitor cannot handle resolutions higher than 720x480. This is more than adequate for mame.
Arcade Addiction
