Author Topic: iPac Key Assignment Question...  (Read 5031 times)
  • Last login:October 08, 2026, 04:08:02 pm
« on: September 27, 2006, 09:40:53 am »
How do I change the key entry for my iPac?  I have 2 buttons on my CP that I want to turn into "Pause" and "Exit to Front End" so I need the button presses to activate the"P" and "Esc" keys on the keyboard.  The other functions defaulted to the buttons I wanted (joysticks up, down, left and right and buttons 1-6, 1P start and insert coin).  How do I set this up?
Thanks!!
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: iPac Key Assignment Question...
« Reply #1 on: September 27, 2006, 01:53:57 pm »
You need to install the WiniPac software that came on the disc you should have had with your iPac.
You can drag round the objects you need and re-create your own control panel on-screen, then you assign key-presses to the buttons and hit 'program'. It then saves the configuration to the eeprom on the iPac. Please note though that programmable config is not available on the USB version of the iPac and you have to stick with the default MAME keys, but this shouldn't be too much of a problem as the two functions you need are already programmed to two wires on there. And although you can't program the iPac to set each connection to the button you want, you can still save button configurations as .ipc files on your PC. Then it's just a case of setting up your other emulators to match your keymap.
Go to the Ultimarc website for more support. They give you a colour-code map of each of the wires' default settings, and you can download WiniPac from the website as well.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #2 on: September 28, 2006, 08:25:24 am »
If you only need to change two key assignments it may be easier to do it through the IPAC's programing mode.  Reboot your computer with your keyboard hooked up to the IPAC's keyboard pass through (if it isn't already), open notepad, hit ctrl-alt-p, and bingo.  It will tell you what to do, but basically you hit the button on your panel you want to change and then the hit the button on your keyboard you want to assign it to.  There is a write up on this feature here:
http://www.ultimarc.com/interact.html
For some reason, this was the only way I could change certain buttons on my minipac.
« Reply #3 on: October 12, 2006, 12:10:37 pm »
This worked perfectly for me.  Thanks!
