Author Topic: Steering Wheel from Sanwa  (Read 3458 times)
destructor
« on: September 25, 2006, 08:55:20 am »
Hello,
I search infos about Sanwa's steering wheel.
I made this photo from newest Sanwa catalogue.
It looks very interesting but:
1. Is it 360 degrees or not?
2. Is possible to connect this steering wheel to PC or console? I f yes then how?
3. How to connect 2 low-high sticks to PC or console if it's possible?
4. How to connect gas pedal?
5. How works gas pedal? Is it analog?
6. What is price for it?
7. What is catalogue code for it?
Maybe someone knows something more about this steering wheel and accesories?
Can someone translate text from this photo?
« Last Edit: September 25, 2006, 09:00:24 am by destructor »
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Steering Wheel from Sanwa
« Reply #1 on: September 25, 2006, 09:16:38 am »
No need to translate the text from the photo.....
That's a standard 270 degree Sanwa arcade wheel. The same wheel, pedals and gear shifters are listed by Happs Suzo....
Take a look at: http://www.suzo.com/cataloguefiles/20.pdf
Although it is also available as a 360....but you would have trouble interfacing that one.
No, you can not connect it directly to a PC.  It has arcade rated POT's on it. You could change the pots for ones of the same value you get in PC joysticks and solder the wires to a D connector, then it would plug into a PC.  But this will be a very very expensive item. If you have loads of money to spare then go for it!
Yes the pedal is analog.... again you would need to change the POT's and wire it into the D Plug.
The high low sticks are switched.... they just have a microswitch for the high and low position. So you could wire those to your keyboard encoder switch inputs for use in Mame.
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: September 25, 2006, 09:33:08 am by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
destructor
« Reply #2 on: September 25, 2006, 09:27:25 am »
Thanks. Not good news :(
EDIT
Someone knows what 360 degrees steering wheel is possible to connect to PC? With pedal and stick otherwise (stick is smallest problem).
« Last Edit: September 25, 2006, 09:39:53 am by destructor »
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: September 25, 2006, 12:30:51 pm »
It's not necessary to change the pots on a 270 wheel- the AKI and the A-Pac both will work with arcade pots.
360 wheels aren't hard to interface, either.  A 360 wheel is nothing more than a big spinner.  A mouse hack, OptiPac, or Opti-Wiz will do the job nicely.
« Last Edit: September 25, 2006, 12:32:55 pm by Kremmit »
