Author Topic: Very off topic, a simple LED circuit needed.  (Read 1474 times)
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« on: September 24, 2006, 03:20:02 pm »
Hey guys. I am working on a project for my halloween costume for school (it's a competition and I don't want to lose).
I have this really campy cobra-head cane. I want to drill out where the eyes are and put in some LEDs and make the glow, for the extra cheese factor. Now, I can get LEDs and resistors and all that, I just need to easiest way to make a small circuit capable of running 2 LEDs (green) using a battery or something.
Any advice would be great.
Thanks.
I had to beat them to death with their own shoes...
Buddabing
Re: Very off topic, a simple LED circuit needed.
« Reply #1 on: September 24, 2006, 03:34:14 pm »
Without knowing your LED specifications, it's impossible to give exact numbers.
Let's say your LEDs require 20ma of current and drop 2 volts each, and you're using a 9 volt battery, like are commonly used in smoke detectors. This is pretty typical.
For simplicity you can put everything in series. Battery, LEDs, and resistor.
To calculate the resistor, use v=i*r. V=the remaining voltage that is not dropped across the LEDs, which in this case=9-2-2=5 volts. i=0.02 amps (20 milliamps),
This gives R=250 ohms.
You can google for much more detailed info. The first link I got was http://unclean.org/howto/led_circuit.html
Regards,
Buddabing
Please read the wiki!
Gambit
  • Last login:November 16, 2006, 09:40:19 am
    • The BlueSparks Network
« Reply #2 on: September 24, 2006, 04:08:17 pm »
What would be cool, would be pulsing LEDs for the eyes.
Not flashing on and off, but slowly growing brighter then slowly growing dimmer.
BobA
  • What Me Worry?
« Reply #3 on: September 25, 2006, 08:57:06 pm »
Here is a circuit sold to fade on and off.  Used for LED eyes.  The picture will give you an idea of the parts needed if you want to build your own.
http://www.cowlacious.com/LightProd.htm
« Last Edit: September 25, 2006, 09:00:54 pm by BobA »
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
« Reply #4 on: September 26, 2006, 01:09:30 am »
http://www.instructables.com/id/E9D2ZJ3FG0EP286JEJ/
Since it sounds like you just need it for a few hours, a flat battery, some wire, and a couple LEDs would do it.
