Author Topic: Need help with Mamewah  (Read 3273 times)
Jedirampage
  • Last login:July 08, 2008, 06:54:08 pm
« on: September 22, 2006, 08:53:51 pm »
hello I am very much a newb to this and I need help bad,
I'm currently building my 1st cabinet and am currently working on the software, I have worked with the Mame32 GUI extensively however I have barely used the command line version of Mame and here is the issue that I am having.
I currently have Mamewah V.97 (configured via the mamewah-setup program), and am currently trying to configure it with Mame.  I can get all of my games to work in Mamewah EXCEPT for my Capcom fighting games.  This list includes Marvel Vs Capcom, Marvel Superheroes, and X-men vs Street Fighter.  These games work fine when loaded with Mame32 however when I load them in Mamewah the game will go to the load screen and upon reaching 100% the screen will turn black and Mamewah will freeze.  Leading to me having to shut Mamewah off in the task manager window.
Here is the current software that I am using
Mame32 V108 (used to test games to make sure that they work).
Mame: V108 (version found in the whats new text file)  and to run mamewah with
Mamewah V97, (configured via the mamewah-setup program found online
Again any help would be appreciated.
« Last Edit: September 23, 2006, 04:52:21 pm by Jedirampage »
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Need help with Mamewah
« Reply #1 on: September 23, 2006, 07:35:44 pm »
First start with the obvious. Make sure your romsets match the version of MAME. Remember, all of these roms depend on the parent rom (mvsc) being correctly checked by MAME. If your version of MAME does not match the version the rom was intended for, straight away you could buggered.
As it happens, I have had a similar problem, and I may have to re-download some roms to make sure none of them are corrupt.
Secondly, I think there may be a problem between colour depth settings/resolutions my monitor can display and the resolution these games require. The reason I suspect this is because when I was setting up MAMEWAH on another PC and monitor, I copied the settings over from my other PC exactly. What I didn't realise is that I had cetain MAMEWAH layouts in 32-bit colour and other in 16-bit colour. What happened is that when I skipped to a layout in 32-bit colour, it displayed for a few seconds, then closed the the program. It turned out that this monitor could only display up to 24-bit colour. After changing the layouts to 16-bit colour, it was fine.
I've not tried it yet, but I suspect it may be similar for these games. As you can specify the default resolution for all games in a particular emulator in MAMEWAH, you may be over-riding MAME's preferred setting for that particular game. It seems to pass the rom-check OK, so it probably gets to the 'loaded' point and crashes MAME, returning you to MAMEWAH. I can't tell as it happens so fast, but this is probably what happens. Try and check this and resolve it. If you do, let me know!
Jedirampage
« Reply #2 on: September 23, 2006, 08:09:48 pm »
Samshaw,
I got the games to work but only after downloading certain patches (japanese for M vs Cap), and the US patch for  Xmen vs SF), and thoughts on why it would work under one version and not the other.  Also everytime I refresh my gamelist in mamewah it says that the roms come up missing and I have to remap the file.  Any advice you can give.
Jedirampage
« Reply #3 on: September 23, 2006, 08:42:30 pm »
also, where would i go to adjust the resolution settings
my58vw
  • Last login:July 21, 2010, 01:22:43 pm
« Reply #4 on: September 23, 2006, 11:46:22 pm »
I am working on this exact issue with mamewah and the three games in question right now...
Jedirampage
« Reply #5 on: September 24, 2006, 12:01:43 am »
which games are they?
NightGod
« Reply #6 on: September 24, 2006, 02:20:57 am »
I would start by upgrading Mamewah from .97. It's up to 1.62b12 or so now, and there have been significant changes made to get things working right with MAME 1.07+
Turnarcades
    • Turnarcades
« Reply #7 on: September 24, 2006, 08:09:28 am »
First make sure they run OK from MAME, before trying to execute them in MAMEWAH. I'm in agreement with the last post - Move to a much newer version of MAMEWAH. Not sure if it will make much difference with this problem, but I initially tried 0.97 thinking that the setup tool would be great and make things easy. I found it was just another component in the setup process to create conflicts and mess up what I tried to do.
I think the biggest problem between MAME and front-ends is that the front-ends are built around a specific version of MAME (MAMEWAH in particular) It makes for a better-looking front-end, but means that any version mis-matches cause unexpected errors. The key to troubleshootong compatibility problems is to check first that your emulator runs it perfectly on it's own, then have a look around the 'config' and 'ini' files of both the emulator and MAMEWAH to make sure things tie up.
As for your question regarding resolution settings location; in MAMEWAH it is in the 'default.ini' (I think). In MAME I'm not sure. Just read EVERYTHING you can in the configs of both and you may see a difference.
Jedirampage
« Reply #8 on: September 26, 2006, 11:08:47 am »
I got all the games to work, and I have no idea how I did it.  Very weird.
