Author Topic: Marquee retainer  (Read 1656 times)
SithMaster
Marquee retainer
« on: September 19, 2006, 09:27:11 pm »
i just got my happs retainers and im fairly certain i should tape off the area im going to be drilling to prevent cracking.  what kind of tape should i use.  masking right.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: Marquee retainer
« Reply #1 on: September 19, 2006, 10:17:18 pm »
You can tape off using masking but I dont expectyou will have any problem with the few holes you need to mount.
Its plastic not plexi or lexan....
...best of luck.
Steve
SithMaster
« Reply #2 on: September 19, 2006, 10:31:46 pm »
ah then it is just me being worried.  what about using a small bit then a larger bit?  just worried it will crack.  if anything ill drill the center hole for the top to see how well it goes.  thanks.
NightGod
« Reply #3 on: September 20, 2006, 12:08:08 am »
Put a piece of wood behind it to help steady it and drill away. Plastic drills very well-better than wood, IMHO.
Czapala
  • Last login:May 18, 2009, 11:04:35 am
« Reply #4 on: September 20, 2006, 08:49:09 pm »
I would not worry.  When I got my Happ retainers I used a tablesaw to cut it to the right length.
Heck I even used the table saw to trim off the extra from the bezel I got from Happ.  :dizzy:
So I don't think a drill will crack it.
.... then my daughter said "Daddy, those games are old."
Lewis Black
  • Last login:October 17, 2012, 08:14:10 am
  • Baaaah Eff it!
« Reply #5 on: September 20, 2006, 09:50:52 pm »
Yes, their plastic is very easily drilled.  Drill from the good side through to the hidden side.  The only thing you might need to do is pull away some of the 'twisty' remnants from the back.
SithMaster
« Reply #6 on: September 22, 2006, 07:31:48 pm »
i drilled the holes for my retainers and used bolts to hold them in since the holes were all the way through.  the top retainer isnt what im worried about now though its the bottom one.  its at an odd angle so when i drilled the holes there was only maybe an 8th of an inch of plastic on the edge of the retainer left.  does that make sense?  not the way it is but my wording.
it seems the plastic is sturdy so i think it will be fine.  only thing left to do is paint the bolts black since it was either sliver or im going to say brass.  and i used black posterboard to stop light from bleeding around the marquee.  yey me.
