Author Topic: Help identifying Wico Trac size  (Read 2047 times)
Boris the Spider
  • Last login:April 08, 2007, 10:16:31 pm
« on: September 19, 2006, 02:38:43 pm »
I'm trying to do a trade with someone on this forum for their Wico trackball. I'm trying to find out the size of this trac. The member says that:
"The interior diameter, where the ball's hole itself is, is
2".  Now, the "rim" around the ball, the exposed part on the CP, is 2 1/4"."
Can someone confirm if this is a 2" or 2.25" trac. I wasn't aware that Wico made a 2" trac but I could be wrong. Basically, I need a trac that will accept a billiard ball as a replacement ball. Will this one work for that?
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
Re: Help identifying Wico Trac size
« Reply #1 on: September 19, 2006, 03:14:31 pm »
Yeah, it's mine and we can't quite figure it out.  It certainly is smaller than the standard Centi trac, so pretty sure the Centi is a standard pool ball. . .
Anyone know for sure, tho?
BTW, no part number on the exterior.  Bottom just says WICO CORP PATENT PENDING.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: September 19, 2006, 04:12:13 pm »
I think it's a 2.25 trackball.  I'm guessing from that the standard 3" TB has a 3" rim and 2.75" hole.
I'll check my 2.25" TB when I get home, but I'll lay money that you're looking at a 2.25" TB.
Robin
Knowledge is Power
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« Reply #3 on: September 19, 2006, 04:30:27 pm »
coooooooll i have one thats looks just like that from a crystal maze machine jsut wanted to say
Texasmame
  • Ba, ba, boom!
« Reply #4 on: September 19, 2006, 08:16:59 pm »
Centi would be 2.5 then, correct?
spidermonkey
  • Bombjack junkie
« Reply #5 on: September 19, 2006, 09:15:01 pm »
Centipede uses a 2 1/4"  too.  You may be thinking of Millipede which uses a 3" ball.
"Sinistar has bad breath"
Boris the Spider
« Reply #6 on: September 19, 2006, 09:23:12 pm »
Great! Thanks rebel...I'll take your word on that.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: September 20, 2006, 03:01:20 am »
Too lazy to take apart the TB, and can't find my calipers, but eyeballing looks 2.25" & 2".  More support, happ's 2.25" TB mounting plate (aka a standard 2.25" mounting plate) shows the outside diameter of the rim should be 2.25", and I was able to measure my TB's rim width: 1/8".  And 2 1/4" mounting plate hole - (2 * 1/8" rim width) = 2" TB hole.
You're looking at a 2 1/4" TB.
Robin
Knowledge is Power
shardian
« Reply #8 on: September 20, 2006, 07:38:48 am »
Yes, you can put a pool ball in there. A brand new cue ball is like $5 at Wal-mart.
