Author Topic: PC monitor...resolution and Hz?  (Read 1113 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: September 18, 2006, 07:13:35 am »
Hey all!
I'm building my third arcade now. On the two former I've used
640x480@60hz but now thinking that maybe there could be an
advantage in running higher res or hz.
What do you think? please don't be too purist....but woud 70 or 80hz
be that bad?
Pros and cons? (of hitchhiking )
Tiger-Heli
    • Tiger-Heli
Re: PC monitor...resolution and Hz?
« Reply #1 on: September 18, 2006, 12:39:33 pm »
I use a PC Monitor with MAME - not in an arcade cabinet.
I used to run 800x600@85hz, but that's just personal preference.  (with a 17-inch monitor).
What size screen are you using?
Vector games will look better at higher resolution - recommend at least 1024x768 and more if your monitor will handle it.
I suspect the new MAME artwork (bezels) files will look better at higher resolution as well.
Refresh rate doesn't make much difference.  Anything under 75 Hz drives me nuts for text, but I can't notice the difference in games.
