Author Topic: Install Help - Ideas on Electrical (Light, PC, Monitor)  (Read 1489 times)
whynotpizza
  • Last login:March 23, 2025, 10:01:28 am
« on: September 16, 2006, 02:28:12 pm »
Hey guys,
Ok, now is the time for me to work the electrical in my first cabinet build.
Any ideas on how to deal with the 3 things needing ON/OFF control from an easy location?
Idea #1 - Build 3 electrical junction boxes inside the cabinet, each with a separate 'light-switch' electrical control ON/OFF ... and have 3 light switches mounted in a double gang or equivalent size electrical box, with switches exposed just like a light switch in your house. Then a single wire plugs into the wall.
Idea #2 - Run cheesy electrical cords around and have 3 of these sticking our the back of the cabinet and I plug them in as desired. I know, why even list this option.
Idea #4 - Get some sort of in-line switch mechanism for ON/OFF on the PC power supply. To be honest I have seen folks with these, and in my case I plan to put a LAPTOP engine inside this cabinet, so that won't work for me really. Besides, I want the PC ON all the time, and instead I want control over the Light and Monitor for ON/OFF.
Any thoughts to control in an easy way the ON/OFF of especially the Light and Monitor? PC will remain on like I said most of the time, so no bigee there.
   David
quarterback
Re: Install Help - Ideas on Electrical (Light, PC, Monitor)
« Reply #1 on: September 16, 2006, 04:01:36 pm »
My first reaction is to say "Just get a smartstrip" which (if you don't know) is basically a power strip which will shut off power to outlets 2, 3 and 4 when you turn off the power to whatever is plugged into #1 (a simplified explanation)
But after reading this:
Then it looks like you'll need at least 2 switches somewhere.   You still don't have to have three wires (or even 2 wires) running out of your cab, but you'll need some way to switch the light/monitor off while leaving the PC running.
So, you could: put a powerstrip inside your cab (as many people do) and then run the power strip plug out of the cab and into your wall.  Leave the power strip on all the time and rig up two switches on your cab.  One for your PC and one for your monitor/marquee
OR, some people have computers which can be set to turn on when you press the space bar.  If that's the case, you can just rig up a single power switch which cuts or supplies power from the power-strip to your light an monitor.  Again, leave the power strip powered up all the time.  You hit that switch and your light and monitor should just turn on (or off).  THEN, you press your spacebar (or whatever button you have associated with starting up the PC) and you're good to go.   Using Mamewah (or other front ends) you can shut down your computer from there.... and then start it up via the spacebar again when you want.
OR you could just put in a bunch of individual switches.  I wouldn't go for the gangbox & lightswitch option though because, IMHO, it looks really really cheezy to have a household lightswitch on your cab.  If you DO go that route, then at least use some kind of low profile rocker switch like the one below.
It's easy to 'hide' toggle switches on a full sized cab.  Just put them on top.  Recess them into the wood and nobody will see them.   It really all depends on your priorities, I guess.  Would you rather have a one switch solution or do you really want to be able to switch a bunch of things on and off independently of each other?
-- Chad Tower
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #2 on: September 18, 2006, 02:47:31 pm »
At the least get a surge strip and plug all your stuff into that. It'll consolidate your cords and (hopefully) protect your equipment
As I've been experimenting with my own setup, I can totally understand why you'd like to kill that marquee light without turning off the system. I plan to put a separate light switch on mine just for this reason.
quarterback
« Reply #3 on: September 18, 2006, 05:00:12 pm »
It's funny, I have the opposite feeling.  Part of my own setup allows (will allow) me to turn the lights on without booting the system.   I think my cab looks cool when it's lit up and I like it that way without having the whole PC and monitor running.
-- Chad Tower
