Author Topic: oscar pro spinner losing connection  (Read 1465 times)
gtnshape
  • Last login:October 12, 2004, 12:16:01 pm
« on: March 19, 2003, 02:17:54 pm »
I have an oscar pro spinner with a happs hd trigger stick on a optipac card.  While playing tron if I dont continually spin or move the spinner it will lose connection during the breaks in between levels.  I know the optipac has a 5 sec period of no activity and that may be the cause.  Is there a way to set it to constantly poll the spinner for tron, or any other fix for this?
OSCAR
    • Oscar Controls
Re:oscar pro spinner losing connection
« Reply #1 on: March 19, 2003, 02:48:01 pm »
This is an occurence that happens with a very, very small number of Opti-PAC's for some reason.  I have had correspondence with Andy regarding it, but we have not yet been able to determine what causes the Opti-PAC to lose the spinner connection.  It is not the optic board on the spinner because I have had the opportunity to see this happen for myself.  I put the suspect spinner on a different Opti-PAC and a Hagstrom ME4, and it worked fine.  This ended up being very frustrating for one of my customers & myself because we kept sending optic boards back and forth.  He would say it didn't work right, but when he sent it back to me it worked fine on my Opti-PAC's.
However, every occurence has been able to be resolved by connecting the spinner to the "Trackball" header, and the other control on the "Rotary" header.  For some unknown reason, the spinner seems to actually like the "Trackball" header better.  Try swapping your connections and see if that helps.
gtnshape
« Reply #2 on: March 19, 2003, 03:03:37 pm »
Thanks for the speedy reply...so what your saying is actually swap the spinner wires to the trackball slots on the board and vs versa?  I will try this thank you
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: March 19, 2003, 09:00:40 pm »
I just have to point out Kelsey's customer support RULEZ!
