Author Topic: Understanding Color adjustments on Monitors  (Read 1171 times)
jimmy_bored
  • Last login:October 18, 2006, 12:13:21 pm
« on: September 13, 2006, 10:11:02 am »
Can someone explain or point me to a guide that describes the color adjustments on monitors.  Like the green cut-off, red cut-off,and the rings.  The reason I am asking this is because I can get the color adjusted fairly well, but its a very time consuming process.  What would be nice is something that provides a step by step.  Or maybe theres a color adjustment tool?
Thanks,
Jimmy
grantspain
  • Last login:July 25, 2025, 09:21:43 am
Re: Understanding Color adjustments on Monitors
« Reply #1 on: September 13, 2006, 01:02:59 pm »
it is a time consuming process but the more experienced you get the quicker it gets,one tip use a colour bar test to get the colours correct -if your white is correct then the other colours are likely to be correct
also to add there are loads of threads here giving setup tips,you just gotta look for them
