Author Topic: Help with Dimensions Template for Control Panel  (Read 2991 times)
acampero
  • Last login:June 24, 2007, 09:29:23 am
« on: September 09, 2006, 02:48:57 pm »
I was wondering if anyone had the precise measurements for the control panel that I am using. Is there a standard or do I need to just measure it out. I did preliminary measurements but they are not exact, especially with regards to the distance between the buttons.
I have a Dynamo Cut Corner Cabinet that is running Marvel Super Heroes vs. Street Fighter, so its two joysticks and six buttons.
If anyone has a layout like this is would be greatly appreciated, as I am having custon artwork designed for the cabinet (sideart and control panel)
Attached please find a pic of it
Arn
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
Re: Help with Dimensions Template for Control Panel
« Reply #1 on: September 10, 2006, 09:54:17 am »
what u saying do you want that control panel to print off cus i could stetch it out and re form it if you need that done cus im very board
acampero
« Reply #2 on: September 10, 2006, 03:41:15 pm »
The artist asked for dimensions of the control panel to do his work on it. So I am assuming he will provide me with either a highres bitmap file or a vector based file that I will then take to print.
Arn
