Author Topic: Help setting up TV  (Read 1746 times)
ddw
  • Last login:June 21, 2020, 05:54:12 am
Help setting up TV
« on: September 09, 2006, 12:53:33 pm »
Need help with setting up mame to work with a 24" philips flat screen,ATI radeon x1300 going with dvi to component adaptor , not sure if xp or 2000 would be a better operating system . if i should upgrade to newest mame version  or not. What resolution to set windows in. I know that's a lot of questions. would appreciate the help
 Thank's :)
ddrmanxbxfr
  • Last login:November 04, 2008, 06:06:05 pm
Re: Help setting up TV
« Reply #1 on: September 11, 2006, 05:45:24 pm »
For windows 2000 and windows xp (Xp Faster to install)I think it's just a preference 'cause it's the same kernel..
Just install the ATI drivers and the tv will be detected as an second monitor..
For the resolution i would recomend an 640x480 but it does not really make an difference on a tv (I didn't notice bettwen 1024x1080 and 640x480 on my tv when im using it to watch movies or play games..)
And well the mameversion If your pc is enought recent (1 ghz minimum..) I would recomend to keep the latest version because less bugs in games.. And more games support !
So That's it !..
ddw
« Reply #2 on: September 12, 2006, 10:00:18 pm »
Thanks for the respoance ddrmanxbxfr Iam going to start with  xp and 640 x480 I found in the main forum under bookmarks of interest lot of info about how to set up componet .
DDW
dudebozo
  • Last login:February 17, 2007, 03:06:38 pm
« Reply #3 on: September 13, 2006, 01:58:06 am »
i believe in windows xp, 800x600 is the lowest that you can go.  i could be wrong though.
this bozo thinks, so therefore he definitely is a bozo
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #4 on: September 13, 2006, 05:58:10 am »
If you Right-click on the desktop-->properties-->settings-->advanced-->Adapter
you should see a button that says "List All Modes..."
It will let you choose lower res than 800x600.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
