Author Topic: monitor out  (Read 2400 times)
roberts1k
  • Last login:September 15, 2006, 02:29:23 pm
monitor out
« on: September 06, 2006, 08:05:25 pm »
I Have a Golden Tee Rebuild.  I was playing and about the third hole the screen went black.  I still have sound and the game works minus the screen.  I opened the back and with canned air blew off the monitor chassis.  I did get a picture back with lines through it.  It then went blank again with a horizontal line down the middle.  I thought a chip on the chasiss wasnt seated correctly.  It is a GWEC chassis from 1983 board.  I tried to reseat the chip Lettered IC on the board and labeled NEC JAPAN PC1397C      890IE.   The chip prongs broke and I cannot reseat it.  I am assuming it will affect the monitor, but not make it display at all.  The neck bulb is not glowing either.  I dont know if it was or was not glowing before I reseated the chip.  The chassis is 23 years old.
The monitor is a-WGE1972-H0GS39L/K7200  19
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: monitor out
« Reply #1 on: September 06, 2006, 08:31:15 pm »
Based on what I read, my guess is the Horizontal output has blown... may have taken out the power supply.
I could not find an NTE repalcement for the part#'s you gave so it is hard to say what comes next.
I would not spnd a lot, the monitor is old... we do not carry 19"CGA as there is no way to compete with the cheap offerings.
I would suggest you contact Betson.
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
roberts1k
Re: monitor out
« Reply #2 on: September 06, 2006, 08:53:57 pm »
The monitor is not old the chassis is.  Should I replace the chassis?
Ken Layton
  • Guru
  • Technician
Re: monitor out
« Reply #3 on: September 07, 2006, 12:24:50 am »
A Wells-Gardner k7200 series that's 23 years old???????  Something's not right here. The 7200 series is not that old. I think it was introduced in 1996.
roberts1k
Re: monitor out
« Reply #4 on: September 07, 2006, 08:23:07 am »
The monitor isnt 23 years old the chassis is.  Any advice.  I am going to try ro replace the chassis first.
grantspain
  • Last login:Today at 04:45:25 pm
Re: monitor out
« Reply #5 on: September 07, 2006, 09:29:21 am »
if you have a horizontal line then its a bad solder joint on the fly back or around the frame i/c,scan coil plug, 25volt line or a faulty frame i/c or missing 25volts to the frame i/c
« Last Edit: September 07, 2006, 01:24:29 pm by grantspain »
roberts1k
Re: monitor out
« Reply #6 on: September 07, 2006, 05:37:34 pm »
I am new to this.  Does that all deal with the chassis?  Should I send it in for repair?
