Author Topic: My new ROBOTRON! working again (woot!)  (Read 10258 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: My new ROBOTRON! working again (woot!)
« Reply #40 on: September 26, 2006, 01:07:42 pm »
OK, I knew that much. "Continuity". Thing is, this meter has symbols. i don't know what the symbol is for "continuity".
There's an area where it says hFE. Another where it looks like a square wave. Next to that there's a symbol that looks like this:  .))) with a  ->|-  symbol under it.
There's an area with an Omega symbol and 5 different ratings.
So which is it? I thought the logical thing to do was to try each one and touch the probes together, but NONE make a beep. (Maybe the battery is getting weak)
NO MORE!!
« Reply #41 on: September 26, 2006, 01:12:03 pm »
Your DMM has a manual.  It should explain the settings there.
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:Yesterday at 05:03:14 pm
  • Worthless button pusher!
« Reply #42 on: September 26, 2006, 02:01:33 pm »
You can use Omega to measure for zero resistance.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #43 on: September 26, 2006, 02:32:17 pm »
It will work, as that is how the continuity check is done... won't beep, though.   :)
RayB
  • There's my post
    • RayB.com
« Reply #44 on: September 26, 2006, 04:21:19 pm »
I just checked my house, cuz I got this creepy feeling Chad is in here.
Nope, he's not here. *phew!*
And no, I don't have a manual.
NO MORE!!
« Reply #45 on: September 26, 2006, 04:26:09 pm »
Does it have batteries?
RayB
  • There's my post
    • RayB.com
« Reply #46 on: September 27, 2006, 01:09:14 am »
There's no visible battery compartment, but the back does say it's powered by a 9volt. (I don't see how a digital multimeter would work without power. Geez Chad, sometimes you're so smart and then sometimes...  ;D )
NO MORE!!
« Reply #47 on: September 27, 2006, 09:08:37 am »
That was sarcasm.  And keep in mind that ohm meters (older instruments on which the DMM is based) did not use batteries.  So it's a valid question since it is entirely possible there are stripped down DMMs that also are not internally powered.
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #48 on: September 27, 2006, 02:12:04 pm »
hFE is most likely a capacitor tester
square wave is most likely dc voltage
.)))  I don't have a friggin' clue what that is 'sposed ta be.
->|-  is most likely a diode test, this may also be your Continuity test
Otherwise I think you could use the Ohms scale, just look for a very low reading, like 00.1.
RayB
  • There's my post
    • RayB.com
« Reply #49 on: September 27, 2006, 06:35:58 pm »
QBert: My apologies for this!  :D
(PS: This meter, when I set to the OHMS section, it displays "1", then if I touch the two probes together, the number quickly "counts down" and stops at 0.0)
NO MORE!!
2600
« Reply #50 on: September 27, 2006, 08:09:03 pm »
Sometimes I can't tell if people are serious or joking on this forum.
hFE tests transistors
))) ->|- is continuity and diode test.  The ))) is suppose to be a sound wave like the symbol on your pc where you plug your speakers into.
The square wave is probably a pulse generator.  V and A (AC and DC) are usually pretty standard signs.
A google for your model should turn up a manual.  If not, go to the Fluke website and look at some of the manuals for DMM's.  They usually operate the same and it will give you instructions on how to use it.  When testing transistors and diodes, it's just easier to see a picture.  I've seen lots of DMMs where you have to take the case apart to get to the 9 volt.
Chad,
I would of thought an ohmeter required a battery?  A volt meter I could see not having one, but it's been a long time since I've seen them.
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #51 on: September 28, 2006, 09:24:46 am »
In order to hear a beep, you must turn it to "ohms" or "continuity" setting and then press a button to denote that you wish to hear a beep.  Hope that makes sense.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
« Reply #52 on: September 28, 2006, 09:27:47 am »
That changes from DMM to DMM... neither of my newish DMMs need a button pressed.
Lutus
« Reply #53 on: September 28, 2006, 02:54:12 pm »
Really?
Well then, don't take my word for it  ;)
I have an older multimeter.... obviously!
Buddabing
« Reply #54 on: October 04, 2006, 12:30:32 pm »
FYI do not test fuses in-circuit! You may get false good readings.
Please read the wiki!
