Author Topic: My taito inspired cab  (Read 2911 times)
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
« on: August 31, 2006, 12:14:37 pm »
Starting planing stages of a classic Mame cab. Here are some plans that I have drawn up.
I will be using the multicade cp from arcadeshop. It is for midway galaga/ms pac-man cab but I didn't want to go with that style. I still debate on how to orientate the monitor or what type of monitor I am going to use.
Havoc
  • Last login:January 20, 2010, 07:07:27 pm
Re: My taito inspired cab
« Reply #1 on: August 31, 2006, 01:12:24 pm »
I have an original Taito Cab and the monitor sits more like whats in the first picture.
MYX
    • MYX Digital Blog
« Reply #2 on: August 31, 2006, 04:19:58 pm »
The cab I am finishing now is loosely based around a Taito. Be very careful about your monitor angle and depth of cabinet. When I was still doing the vertical set up the monitor went 1 in. beyond the back of the cabinet (1 3/4 too far). When I decided to go Hoz. this resolved it's self. LINK
Also if you go too vert, over time stuff can fall on the guns and shorten the life of your monitor.
M    Y    X
KDOG
Re: My taito inspired cab with 3d render
« Reply #3 on: September 12, 2006, 12:36:18 pm »
Here is a 3d render of what it will look like.  Nothing fancy just used google sketch . I have found I am an ok artist with paper pencil but I am useless when it comes to artwork using a computer.
As far as monitor type and orientation, I think  I will go with a LCD so that I can easily rotate horz. and vert.
KDOG
« Reply #4 on: September 12, 2006, 05:35:29 pm »
some more detail.
KDOG
« Reply #5 on: September 12, 2006, 05:54:50 pm »
Here is the more laid down look. It would only be vertical with an arcade monitor.
Lord Hiryu
  • Last login:September 29, 2020, 12:05:39 pm
    • Lord Hiryu's Artwork
« Reply #6 on: September 13, 2006, 06:30:51 am »
Hi KDOG.
A few months ago I build from scratch a Taito based cab.
I modified the sizes from the rear of the back and the wide.
Here's a link of all the construction.
I think that may help you.
http://www.marcianitos.org/turecreativa/VerticalArcadium.htm
And this is all the original Post, with all the info:
http://img170.imageshack.us/img170/5577/estadoactualct8.jpg
BTW...the page is in Spanish.:P
Cheers.
Que tiempos aquellos, en el que las vidas se llamaban tanques !
KDOG
« Reply #7 on: September 14, 2006, 12:11:20 pm »
Here is basically what I  am looking for in as far as artwork. I will later get one of the talented people in on the board to help me tweak it better.
