Author Topic: Help with atomicfe thanks a bunch  (Read 1748 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: August 29, 2006, 09:35:01 am »
This is my 2ND time setting up atomicfe, the first time everything worked like a breeze but my cfg became corrupted so I just deleted & re setup again I'm not using mame from the plug & play I'm using 107.1 everything works fine until I install the plug & play modules, they show up fine but the mame is not showing up on the module list where it did the first time, could I please get some help on getting the mame to show up in the list of choices
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Help with atomicfe thanks a bunch
« Reply #1 on: August 29, 2006, 09:48:39 am »
If i well understand :
-You made your own config that it worked well.
-THEN you installed a module
-Now you can use the module but you don't see your previous configuration in the list?
If i'm right :
Open PlugnplayManager.exe
Clique on "Add an existing config" button, make  point "config file to add" field  to your .cfg file (the one you did).
Fill the 2 others field if you want. (you can choose a picture for your config).
Click "Ok"
exit the plugnplaymanager.
Run Atomic.Exe  , now , you should see your config in the list next your modules.
divemaster127
« Reply #2 on: August 29, 2006, 09:53:29 am »
hello, my mame 107.1 is set up on its own,  I just pointed the folders from atomicfe to my mame 107.1, it worked perfect then I added the plug & play nintendo 64 now only the nitendo 64 shows up, so if I do the above that should fix the problem I just want to add the mame so it shows up in the list it worked the first time just not this time
thanks
dm
youki
    • Atomic Front End
« Reply #3 on: August 29, 2006, 09:59:50 am »
If you do what i said previously it should work.
I think the first time you did the same thing. Because it is like that it works.
If you install a plug'n play module , Atomic run in "plug'n play" mode and ignore non-plug'n play config.
To see you own config in the module list, you have to use PlugnplayManager.exe and add the config as i said.
divemaster127
« Reply #4 on: August 29, 2006, 10:06:21 am »
thanks a bunch I really appreciate the help
dm
