Author Topic: AdvMenu/ROM merge help  (Read 1183 times)
FLAPS
  • Last login:April 08, 2014, 04:06:35 pm
« on: August 28, 2006, 08:51:20 pm »
I
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
Re: AdvMenu/ROM merge help
« Reply #1 on: August 30, 2006, 09:28:31 am »
Well I know you can run clone but I'm not sure if there is a way or not to exclude a particular clone. Even if you had a way to select a different default clone (2 player in your case) that would solve your problem but I haven't ever looked into that one either.
Maybe i'll play around with it if I have some time.
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #2 on: August 31, 2006, 02:17:36 am »
It is a bit tricky because clones normally inherits the parent settings. Here is a way to do it.
1. Create two groups called "excluded" and "included"
2. Move the clones you want to see to the "included" group.
3. Move the parent to the "excluded" group.
4. Set up so that the group "excluded" isn't shown.
