Author Topic: Keywiz/IPac : which SOFTWARE is the more practical ?  (Read 1912 times)
Jeehemdee
« on: March 16, 2003, 07:20:26 am »
Hi...
Between the Keywiz and IPac, I have difficulties to guess which is the best..when you speak of SOFTWARE:
the more practical and easy...
Thanks for your help ;-)
eightbit
  • My cab is never done...
Re:Keywiz/IPac : which SOFTWARE is the more practical ?
« Reply #1 on: March 16, 2003, 11:20:11 am »
Both of them have software that programs them. Functionally they are similar. I would say most people don't use this software because in most cases the default key configuration works well. Both applications have a nice GUI interface. Both of them can be run from a command line to program the interface on the fly. One nice feature of the keywiz software is the on screen keyboard, so you can create key configurations without dragging out a keyboard.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #2 on: March 16, 2003, 02:11:46 pm »
I haven't used either - I have a Hagstrom KE72, which probably has the most UNintuitive programming method.  That said though, once it's set, you never really need to use it again.  I guess my point is that I certainly wouldn't let this be a major deciding factor with my choice of encoder (unless you DO see yourself programming and reprogramming it a lot).
Kane
  • Last login:June 06, 2023, 08:05:47 am
  • What?
« Reply #3 on: March 16, 2003, 02:33:12 pm »
I can only tell you about the KeyWiz, but for a newbie it was quite simple for me to set up. I just wish Randy would finish setting up the website :)
