Author Topic: Hanatrex mtc 9000 dead or not?  (Read 2851 times)
kdjac
  • Last login:August 22, 2006, 10:55:48 am
« on: August 21, 2006, 11:12:04 am »
Lo
I have a sort of wkring arcade cabinet with a hantrex mtc 9000 in it, when i turn on the cab i hear speakers the monitor flashes in all corners (white flash only in corners) then sound kicks in as game is loaded but no video.
Once i seen a rom loading screen but since then all i get is flashes.
Is this a common symptom of a dead monitor? I am reluctant to poke about in it and owuld prefer to get a mate who is an electronics guy to have a look at it, as it looks fairly basic is there a checklist of things he can check or clean before diagnosing a dead monitor?
thanks
kdjac
Ken Layton
  • Guru
  • Technician
Re: Hanatrex mtc 9000 dead or not?
« Reply #1 on: August 21, 2006, 11:23:46 am »
Does your game play "blind" too? If so then the monitor is the problem. Hantarex are well known for needing capkits due to the great number of failed capacitors.
kdjac
« Reply #2 on: August 21, 2006, 02:01:38 pm »
I have yet to try the dipswitches for free play on the game so i only hear it running.
Will have to find out which dipswitch is for free play before i can find that out.
thanks for reply.
kdjac
grantspain
« Reply #3 on: August 21, 2006, 02:07:49 pm »
do you know how to meter voltages etc?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 21, 2006, 06:27:18 pm »
Can you manually coin it up with the coin switches?
kdjac
« Reply #5 on: August 21, 2006, 06:44:31 pm »
I take some pics of it tomorrow and you can judge its state, i bought an Xbox today so moving along with that idea.
Heh the currency it set for no longer exists (punt we use Euro now )  :)
Thanks for replies.
kdjac
Kevin Mullins
    • Me on Myspace
« Reply #6 on: August 21, 2006, 11:17:43 pm »
Ok ... open the coin door and flick the switches.
You don't need to actually drop a coin through the slot.
(unless you don't have a key and need to get it open first)
