Author Topic: i-pac help  (Read 2411 times)
xcalibur
  • Last login:August 22, 2012, 11:15:35 pm
  • You sold my dead bird to a blind kid?
    • Dallas Starcade
i-pac help
« on: March 16, 2003, 01:15:32 am »
Evening all,
I just registered and searched for my problem before posting this so no flaming...
I bought an i-pac 2 weeks ago and last night was the first time I was able to hook it  all up and test it. When I have the I-pac plugged into the PC and a keyboard plugged in the passthrough, it won't work. I'm running Win XP, it boots to the login screen and I can't type my password on the keyboard. Has anyone else run into this problem? I emailed Andy about it and he suggested that I unplug everything and try to boot it that way to see if it was bad wiring. even with just the keyboard plugged into the interface, it won't type.
Thanks, for your time,
Thanks,
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
Re:i-pac help
« Reply #1 on: March 16, 2003, 01:57:30 am »
First of all, what type of ipac?  USB or PS2?
So what I'm getting, is the keyboard won't type even if plugged directly into the PC?  Sounds like a bad keyboard.
Do you have another keyboard to try out?
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
xcalibur
    • Dallas Starcade
Re:i-pac help
« Reply #2 on: March 16, 2003, 10:01:21 am »
no, the keyboard will type once I disconnect the intreface and plug it diectly into the PC. I noticed when I have the interface connected, the caps lock light will come on when the external kb is plugged in, but it still won't work.
Thanks,
MrToasty
  • Last login:July 10, 2007, 12:33:21 pm
Re:i-pac help
« Reply #3 on: March 16, 2003, 12:43:48 pm »
Are you using USB?  If so, do you have the USB jumper set on the IPAC?
xcalibur
    • Dallas Starcade
Re:i-pac help
« Reply #4 on: March 16, 2003, 01:49:59 pm »
I'm using a PS2 connection and I've tried 3 different keyboards.
« Last Edit: March 16, 2003, 01:50:39 pm by xcalibur »
Thanks,
Odonadon
    • Turbo2k
Re:i-pac help
« Reply #5 on: March 16, 2003, 02:56:59 pm »
Maybe it's a bad ipac.  Sounds like the PS2 in port might be bad or have a bad connection to the main board.
Odonadon
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re:i-pac help
« Reply #6 on: March 17, 2003, 07:37:15 am »
Do the buttons and joysticks connected through the I-Pac work?
-Ace-
I want my own arcade controls!
Bursar
  • Last login:September 14, 2005, 06:57:07 am
Re:i-pac help
« Reply #7 on: March 17, 2003, 07:41:11 am »
I suffered from this problem once as well. Found out I had something resting on one of the buttons. D'oh!
Might be worth double checking your wiring to make sure there isn't a short somewhere that's causing it.
  • Last login:July 24, 2026, 10:46:46 pm
Re:i-pac help
« Reply #8 on: March 17, 2003, 01:21:23 pm »
Shorts in your wiring will cause this too..... in other words it's probably your fault, no offesense.  It happens to everyone at one time.
xcalibur
    • Dallas Starcade
Re:i-pac help
« Reply #9 on: February 13, 2004, 03:54:49 pm »
it was a bad ipac. Andy sent a new one and it works like a charm. he says there was a huge scratch all the way across the contacts. It may have occurred in the shipping. there were 2 joysticks and a crap load of buttons along with it.
Thanks,
