Author Topic: Question about the Nintendo VS board pinout  (Read 3697 times)
Masterful Gaze
  • Last login:January 28, 2012, 02:35:56 am
« on: August 18, 2006, 06:13:15 pm »
I've been searching around the net for the Nintendo VS pinouts so I can put together a harness. Most of the places i've seen have this listed as the pinout:
This Video Game Pinout Data Sheet Was Typed In By Chris McBride.
                     EMail:  mcbride@cs.arizona.edu
                     -> VS. Unisystem Standard Connector <-
Name Of Game: vs Super Mario Brothers
       I assume it also works in other vs. systems:
         vs. Duck Hunt, vs. Excitabike
Notes: This is for the Single Monitor upright systems.
            Solder Side            |             Parts Side
   ________________________________|___________________________________
               GND              A  1              GND
               GND              B  2              GND
               +5                C  3              +5
               +5                D 4               +5
               +12              E  5              +12
                                   F  6
             M Coin 1         H  7           S Coin 1
             M Coin 2          J  8           S Coin 2
             M Red              K  9           S Red
             M Green           L  10          S Green
             V. Gnd             M  11          V. Gnd
             M Blue             N  12          S Blue
             M Sync             P  13          S Sync
                                     R  14
                                     S  15
              + 24V              T  16           + 24V
            M Counter         U  17          S Counter
                                      V  18
            M Service           W  19          S Service
            M Sound             X  20          S Sound
               GND                 Y  21             GND
               GND                 Z  22             GND
               GND              A  1              GND
             M1 Right         B  2            S1 Right
             M1 Left           C  3            S1 Left
             M1 Up             D  4            S1 Up
             M1 Down        E  5            S1 Down
             M1 A Switch    F  6            S1 A Switch
             M1 B Switch    H  7            S1 B Switch
             M Select 1        J  8            S Select 1
             M Select 2        K  9           S Select 2
             M Select 3        L  10         S Select 3
             M Select 4        M  11         S Select 4
             M2 Right           N  12         S2 Right
             M2 Left             P  13         S2 Left
             M2 Up               R  14         S2 Up
             M2 Down          S  15         S2 Down
             M2 A Switch      T  16         S2 A Switch
             M2 B Switch      U  17         S2 B Switch
               GND                V  18             GND
Does anyone know what the M's and S's mean?
« Last Edit: August 19, 2006, 04:58:19 pm by Masterful Gaze »
Dav
  • Last login:March 29, 2016, 05:39:35 am
Re: Question about the Nintendo VS board pinout
« Reply #1 on: August 19, 2006, 03:18:20 am »
I don't know that I've ever actually seen it defined, but I always assumed it meant master/slave.
Rocky
« Reply #2 on: August 19, 2006, 09:13:13 am »
Main and Slave
It refers to the 2 monitors / CP's for a dual system
Kevin Mullins
    • Me on Myspace
« Reply #3 on: August 19, 2006, 11:29:08 am »
That applies if your board is labeled MDS...... which like they have already mentioned is a Dual Sytsem board for running two game at once on two monitors with two control panels. Two seperate locations for ROMS.
Masterful Gaze
« Reply #4 on: August 19, 2006, 04:41:51 pm »
Thats what I was thinking, but at the top it says
Typo I guess?
Kevin Mullins
    • Me on Myspace
« Reply #5 on: August 19, 2006, 05:47:23 pm »
It also says it's for Super Mario Brothers which is found on these dual system boards but only running on one bank of ROMs. You can run only one game to one monitor and control panel. You do not need to actually have both games going.
Is this the board you have? (MDS)
I have a complete .vs manual with schematics , etc, I just want make sure it's the MDS information you need. Which is what those ".vs kits" used.
Masterful Gaze
« Reply #6 on: August 20, 2006, 07:30:51 am »
Thanks for the info, helps me out alot and yeah it's the MDS version.
