Author Topic: Staining and T-miolding soon?  (Read 4253 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: August 17, 2006, 03:31:37 pm »
Hey guys I am going to be staining all my pieces soon.  Maybe even start this weekend.  My question is should I stain the bottom of the base and even the base boards?  Just wondering.  I will be doing pretty much everything else both sides of every piece.  I am going to start sanding some pieces this weekend.  I would like to get the two big cabniet side pieces out of the way first.  I will be doing the staining inside when the 2 year old is asleep at night.  Another thing I need to ask is about slot cutting.
I am going to use a slot cutter bit on the router for some tmolding.  Here is my question.  I want the T-molding to go all the way around.  I will stop about four inches in on the bottom.  Here is my thing when I get down to the area that is going to be behind the control panel, and underneath the control panel.  Should I slot cut that out, so I will have T-molding under/behind the control panel box.  Or should I stop around the area where the control panel box is.  I don't want the box to sit uneven or anything like that.  You know what I am saying?
JONTHEBOMB
  • Last login:March 28, 2025, 11:39:04 pm
  • BOOM!!!!
Re: Staining and T-miolding soon?
« Reply #1 on: August 17, 2006, 09:35:25 pm »
You really don't need to stain the botton of the base or the base boards unless you want to.
I had this exact question come to mind when I cut the slot for the T-molding on my cabinet.  For my cabinet I did not cut a slot for the T-molding under or behind the control panel because I thought the control panel wouldn't sit right.
NightGod
« Reply #2 on: August 17, 2006, 09:59:48 pm »
Slot the whole thing and then decide if you want it there or not when you put it in-better to have a slot in a hidden area that you don't use than to try and slot it after it is assembled because you decided you want it.
rdowdy95
  • This is my rifle.
« Reply #3 on: August 18, 2006, 11:25:57 am »
NightGod does your control panel sit right on the T-molding?
JON nice cab from what I am seeing.  Did you use Lucid's plans?
Is that some extra support cross beam under the monitor shelf.  NICE! I love the wood look!
JONTHEBOMB
  • BOOM!!!!
« Reply #4 on: August 18, 2006, 04:00:03 pm »
Yep, I used Lusid's plans.
Actually I put the monitor shelf about one inch to high.  So in between the monitor shelf and the control panel there was just a little space that I covered up with an extra piece of wood.
NightGod
« Reply #5 on: August 18, 2006, 04:17:36 pm »
I haven't put the T-molding in place yet, trying to decide if I want to run it under the CP or not =) But I have the cut there so I can go either way-if I decide not do it, you'll never know the slot is there because it will be hidden under the panel.
