Author Topic: Custom Resolutions file for Powerstrip?  (Read 1000 times)
MartyNg
  • Last login:April 26, 2014, 11:37:48 am
« on: August 14, 2006, 10:14:13 pm »
I have a Wells Gardner monitor bring driven by a GeForce 2. Do any of you guys have a custom resolution file with lots of resolutions in it? The ones in the "Powerstrip Writeup" thread are minimal. Thank you!
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: Custom Resolutions file for Powerstrip?
« Reply #1 on: August 15, 2006, 11:15:34 am »
No, but I am keen to make one in the future.
The main issue is that you would probably need slightly different ones for different monitors (in terms of tweaking/positioning) I think...
The wiki has some info on creating resolutions, but these were taken from that thread. I know it has a list of resolutions similar to the ones the AVGA uses, except with doubled horizontal frequency (to increase the pixel clock to make it more likely to be doable on a standard graphics card.)
It was only recently that powerstrip had its pixel-clock floor lowered as they used to assume that no standard graphics card could go down below 5Mhz pixel clock. I think the floor is now 2 or 3Mhz, as I know at least some ATI cards can get down that far. I suspect that the very low resolutions (240x200) may be too low, but 320x200 should be doable.
