Author Topic: can anyone give me the x arcade byo kit circuit board dimensions  (Read 1049 times)
muell67
  • Last login:May 23, 2021, 02:12:01 pm
Im trying to figure out if Im going to use a x arcade byo kit for my next console joystick. Im trying to go as small as possible and I need to know the size of the circuit board so I can determine if it will fit into my plans. Thanks in advance if anyone can get them for me.
I don't know if you know this but I'm sort of a big deal. I own many leather bound books and my apartment smells of rich mahogany.
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
Re: can anyone give me the x arcade byo kit circuit board dimensions
« Reply #1 on: August 12, 2006, 12:07:40 am »
5"x2", assuming it's the same size as the board inside the X-Arcade joystick (which the connections are all the same, and it looks the same size).  One thing to keep in mind about the size is the huge connector of the wire that hooks up to it - it's a VGA cable, so the connector is pretty large (the connector on the board is coming off the long edge at a corner).
muell67
« Reply #2 on: August 12, 2006, 08:58:13 am »
thanks
