Author Topic: ADVMENU CONFIG EXAMPLES !!!  (Read 1626 times)
Elastikman
  • Last login:September 01, 2006, 10:35:34 am
« on: August 11, 2006, 04:42:56 pm »
Hello!
I finished building my cabinet, all software is already config...
but i want to make advmenu a little bit more atractive..
I  have read the txt files ..but is so many options avaibab
Elastikman
Re: ADVMENU CONFIG EXAMPLES !!!
« Reply #1 on: August 12, 2006, 10:05:00 am »
Come on buddy!! Dont be so attach to your config files  :cheers:
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #2 on: August 14, 2006, 11:30:07 am »
Don't have my config file available (it is in my cabinet). It might be easier if you explain what you want to do.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #3 on: August 14, 2006, 04:36:57 pm »
Here is the ui options I currently have
ui_bottombar yes
ui_clip single
ui_color help lightgreen black
ui_color help_tag lightgreen black
ui_color submenu_bar lightgreen black
ui_color submenu_item lightgreen black
ui_color submenu_item_select lightgreen lightblue
ui_color menu_item white black
ui_color menu_hidden white black
ui_color menu_tag lightgreen black
ui_color menu_item_select lightgreen blue
ui_color menu_hidden_select lightgreen blue
ui_color menu_tag_select lightred blue
ui_color bar lightgreen black
ui_color bar_tag lightgreen black
ui_color bar_hidden lightgreen black
ui_color grid lightgreen lightblue
ui_color backdrop black black
ui_color icon white white
ui_color cursor gray white
ui_command_error Error running the command
ui_command_menu Command
ui_console no
ui_skipbottom 0
ui_skipleft 0
ui_skipright 0
ui_skiptop 0
ui_topbar yes
