Author Topic: How to tweak a Happ Super  (Read 1180 times)
« on: August 11, 2006, 02:24:38 pm »
I've got a couple supers that I'm trying to tweak to work as good as possible. I have them setup in 8 way mode.
How do you guys tweak yours? What I've done is bend mine at the microswitch to where the tip of the arm is touching the actuator. This seems to work ok. The problem I'm having is if I'm pulling up on the joysticks and moving in a direction, the microswitch arm will go under the eclip and not register the move(and make a pretty nasty grinding\clicking noise). Usually during a game of robotron when I'm working the sticks pretty hard. If I move it nice and calm - it works fine.
Thoughts?
