Author Topic: SlikStik + Coin Door  (Read 1845 times)
patm95
  • Last login:January 11, 2026, 10:16:48 pm
« on: August 10, 2006, 07:09:58 am »
Hello all.  I am new to this and doing some research before I go crazy buying parts.  Ordered Saints book and can't wait to get it.  Anyway, from what I understand you need an Ipac to get a coin door to work when you insert quarters.  I have been thinking about getting a SlikStik to save time from having to build my own controls.  Is it compatable to have both a SlikStik and Ipac installed?  If not, I may just build my own controls.  I am planning on building a 4 player system.  Thanks.
2600
Re: SlikStik + Coin Door
« Reply #1 on: August 10, 2006, 07:42:59 am »
Any Encoder will work with a normal coin doir, ie I-PAC, KeyWiz, GPWIZ, A-PAC, J-PAC, OptiWiz, OptiPAC, Ultimarc 360, etc, etc.
As the SlikStik Website mentions, The SlikStik control Panel uses an I-PAC.
patm95
« Reply #2 on: August 10, 2006, 07:48:07 pm »
Thanks for the input.  I was thinking that the slikstik used usb.
Flip_Willie
  • Last login:November 02, 2020, 11:20:46 pm
    • FlipWillie's Site
« Reply #3 on: August 10, 2006, 08:14:42 pm »
    Where did you order the book from?  I am just curious, seeing as I would be very interested in reading it.
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: August 11, 2006, 11:59:41 am »
i hacked a cheap pc gamepad for my coin door, you can use just about anything
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #5 on: August 11, 2006, 12:27:39 pm »
The Ipac uses USB.  USB is just an interface, it is the encoder that actually "does the work"
As mentioned, any encoder can be used for a coin door... hacked gamepad, Ipac, Keywiz... whatever.  All it is doing is registering a keypress once a coin is inserted, so its not a big deal on exactly *how* the keypress is "made"
first off your and idiot
patm95
« Reply #6 on: August 13, 2006, 10:11:40 pm »
Thanks for all the info.  FYI, I ordered the book from Amazon.com  I think that they have about everything lol
