Author Topic: Moniter is here, Arcade VGA over there, and a bunch of chopped wires in middle.  (Read 1917 times)
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
OK I got a  27" dotronix monitor from GGG and it has a 9pin VGA hook up.
I got a Arcade VGA card from Ultimarc with a 15pin VGA hook up.
I got a 15pin VGA cable cut  and stripped.
Got a Radio Shack 9pin connector plug end.
Got a multi meter with a crap load of dial settings on it.
So help me out. I guess I'm looking for continuity from wire to pin with multi meter.
I get the part about red thingy on one side and black thingy on other but what about all these settings on the dial?
Am I on the right track? :banghead:
They treated me like an animal and that's what I became.
krick
  • Gotta have blue hair.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
grantspain
 :laugh2: :laugh2:,sorry but this is funny-if you want to meter continuity in cables its best to use either ohms setting or better if you have a bleep test(gets your leads in correct black always to common and the red should go to volts ac/dc,ohms not amps)-once again sorry to laugh :laugh2:
rackoon
  • I EAT PENCILS!
I don't get whats so funny. I don't know what I'm doing. I'm not sure continuity is even what I'm looking for. :tool:
rackoon
  • I EAT PENCILS!
Ok let me just ask this:
How do I figure out witch pin goes to what wire? :lame:
grantspain
yeah i'm sorry its just the first thing to do is learn how to use a meter,otherwise you could get the wrong info
the pin connection is pretty straight forward,obviously you will have to cut one of the svga plugs off then strip back the wires then use your meter to trace i.e red(some svga have seperate grounds for each input some don't)
so using the link that krick gave you red will go from pin1(svga) to pin 1(vga)
following;
2 to 2
3 to 3
13 to 4
14 to 5
6 to 6
7 to 7
8 to 8
10 to 9
alternatively you should be able to purchase an adaptor thus sorting your problem with ease :tool: ;D
rackoon
  • I EAT PENCILS!
I took a look at that site but it doesnt tell me anything that I dont already know. My monitor lists what pin is what and Ultimarcs site lists what pin is which.
What I have is a cut 15 pin cable that I need to conect a 9pin end on so I cut the cable and striped the wires. They are not marked they are just colored. How do I know which wire is the #1 pin ect. :hissy: :cheers:
RandyT
  • Last login:May 31, 2026, 03:12:30 pm
    • GroovyGameGear.com
If you get a nice bright light (and maybe a magnifying glass) you can see the pin numbers formed into the plastic right next to the pins.
So set your multi-meter to ohms (or better yet, continuity) and put the red probe to a wire and keep hitting pins with the black probe until you hear a beep (or you get a display full of zeroes.)  Write down which pin is associated with which colored wire, and repeat until you have the cable mapped out.
Then do the same on the other cable.
Then compare the pinouts of each, line up the signals of the same name and connect them together.
You will need to wire the H and V sync lines of the VGA cable together and connect those to the composite sync line of the monitor.
Email me if you get stuck.
RandyT
rackoon
  • I EAT PENCILS!
Damn, Randy T you rock? Worked like a champ.
Thanks brother. :cheers:
