Author Topic: Games include the"bezel" on the screen  (Read 3139 times)
Czapala
  • Last login:May 18, 2009, 11:04:35 am
« on: August 04, 2006, 08:25:24 am »
I was wondering.  I notice that some games include what looks like the bezel (w/graphics) from the original game ON the screen with the actual game play in the middle. IE. game play screen is smaller.  Pacman (midway) and I think  Marvel vs Capcom(?) were a couple that I ran across.  I am sure there are more.
Is there a way to turn that off so that the whole screen is the actual game?  maybe in an ini or something?
.... then my daughter said "Daddy, those games are old."
fatfingers
  • Got UltraStiks?™
Re: Games include the"bezel" on the screen
« Reply #1 on: August 04, 2006, 09:13:27 am »
I cannot remember which folder it is, but I think that artwork is in one of the folders in your mame directory.  I think if you get rid of the files in that folder, the bezels should go away.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
  • Last login:May 12, 2026, 04:25:06 am
    • MaLa
« Reply #2 on: August 04, 2006, 09:39:35 am »
true
or for mame .79 its  the following in mame.ini
set them to 0 not 1
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
Havok
  • Trade Count: (+17)
« Reply #3 on: August 04, 2006, 01:09:41 pm »
true
set them to 0 not 1
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
I have my setup with just the bezels set to 0. The backdrops and overlays will not reduce the size of the image. In some cases, the game just doesn't look the same without them - for example Battlezone wouldn't have the green lines without it, and Asteroids Deluxe wouldn't have the space scene in the background...
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« Reply #4 on: August 07, 2006, 04:09:51 am »
well, I removed the bezel simply because of what it did to Marvel Super Heroes. However I would like to bring back the bezels but only for vertical games - I figure at least the entire screen will be then filled up with some sort of graphic/s.
Is there a way of doing this? To tell Mame to apply the bezel for only vertical games?
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: August 07, 2006, 07:59:09 am »
Semi-Related . . .
See http://www.mameworld.net/tigerheli/arcadepanels/crop43.jpg - You used to be able to do this using a hack that SirPoonga made called -artworkfilledges.
Does anyone know if there is a way to configure the new view settings introduced in MAME 0.107 to do this automatically now?
Buddabing
« Reply #6 on: August 07, 2006, 05:43:04 pm »
I can write a ListGen script to do it. I can create a batch file to mass create/modify all the .ini files to disable bezels for non-vertical games, or to enable bezels for vertical games.
Please read the wiki!
Buddabing
« Reply #7 on: August 07, 2006, 06:07:17 pm »
I went ahead and wrote the script. It assumes your ini directory is named ini.
Take the attached text files, rename them to .bat, and put them in your mame directory. Then run makeini.bat.
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #8 on: August 08, 2006, 04:07:25 am »
Here is a patch that will add back the cleanstretch option to 107u2. A side effect is that borders will automaticly be filled with artwork (both horizontally and vertically). If you also specify artwork_crop the game screen will be as big as possible and the artwork fills the rest. No need to disable bezels.
(both cleanstretch and artwork_crop can be changed at runtime in the video menu)
Read more about the it here
http://web.telia.com/~u84606172/
wpcmame
« Reply #9 on: August 08, 2006, 04:07:26 am »
Double post
« Last Edit: August 08, 2006, 04:12:25 am by wpcmame »
darthbane2k
« Reply #10 on: August 08, 2006, 04:19:40 am »
okay  (bare with me, its early in the morning) so all I do is stick this txt file in my MAME directory, change it into a batch file (.BAT at end) and run it? What is telling it to change the ini of the vertical games? Looking at the txt file, I cant see a command that does this?
Were you meant to include more than one txt file in your post?
« Last Edit: August 08, 2006, 04:26:38 am by darthbane2k »
Buddabing
« Reply #11 on: August 08, 2006, 09:10:27 am »
Yes, the other attachment didn't post. Here it is, rename to .bat also:
darthbane2k
« Reply #12 on: August 08, 2006, 09:19:09 am »
nice one - thanks!
  • Last login:May 05, 2026, 10:44:49 pm
« Reply #13 on: August 08, 2006, 04:57:50 pm »
You guys do know that as of .107 you can turn the bezels on and off inside mame as well as crop/uncrop them.  On top of that mame saves the screen settings on exit so none of this is an issue anymore, set your most likely setting and when you run across one that bugs you turn it off.
