Author Topic: Power Supply from Happs 80-0015-00 manual  (Read 1511 times)
jimmy_bored
  • Last login:October 18, 2006, 12:13:21 pm
« on: August 03, 2006, 09:35:00 pm »
Where's the manual for this power supply.  I am trying to figure out what this blue wire is for sure... I am assuming its -12 volts, but I want to be sure...
Thanks,
JImmy
SirPeale
  • Green Mountain Man
Re: Power Supply from Happs 80-0015-00 manual
« Reply #1 on: August 03, 2006, 09:41:19 pm »
Why don't you just meter it?
jimmy_bored
« Reply #2 on: August 03, 2006, 09:43:44 pm »
I could... But i would also like the manual... For all componets in my cabinets I document everything and create a nice file...
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 04, 2006, 12:02:04 am »
These are all A.M.O.A. standardized power supplies. The 9 pin connector is the DC output voltage. Here is the A.M.O.A. standard pinout:
Pins 1,2, and 3 are +5 volts (generally red wires)
Pins 4,5, and 6 are ground (generally black wires)
Pin 7 is the - 5 volts
Pin 8 is the +12 volts
Pin 9 is not used and is normally empty
jimmy_bored
« Reply #4 on: August 04, 2006, 07:30:53 am »
Thanks for the info.... This supply only has a 6 pin connector for the dc... So who ever had this before me must of hacked it.
