Author Topic: Safe to delete ini's?  (Read 1338 times)
Czapala
  • Last login:May 18, 2009, 11:04:35 am
« on: August 03, 2006, 02:03:53 pm »
so I was going through a res problem:
http://forum.arcadecontrols.com/index.php?topic=56386.0
but I was wondering if it is possible to just go into the ini folder in mame and delete all those files (except for the mame.ini).
I am at work now but when I get home I was going to try that ... maybe.
Is that Safe to do?
.... then my daughter said "Daddy, those games are old."
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
Re: Safe to delete ini's?
« Reply #1 on: August 03, 2006, 03:11:53 pm »
Yes.
loadman
  • Last login:May 12, 2026, 04:25:06 am
    • MaLa
« Reply #2 on: August 03, 2006, 07:12:42 pm »
Yes.
I concure
Any game that does not have a separate .ini file, mame will refer to mame.ini for that game.
I only have a few games that I have a separate .ini file for.
Czapala
« Reply #3 on: August 04, 2006, 08:07:00 am »
Well I deleted ALL ini's in the ini folder.
Then ran mame -createconfig.
Then edited it and turned hwstretch to 0(off). (Per Ultimarc's Monitor FAQ site)
The games look better than they have so far.  Almost perfect.
Edit: Out of curiosity Loadman, which games do you have seperate ini files for?
« Last Edit: August 04, 2006, 08:18:31 am by Czapala »
loadman
    • MaLa
« Reply #4 on: August 04, 2006, 09:33:03 am »
Elevator action and Rally x
For some reason they were upside down when used vertically
so I have the opposite rotate setting for those
